94 Civic VX - Not great MPG - Fuelly Forums
Old 08-01-2011, 12:54 AM   #29
imzjustplayin's Avatar
Re: 94 Civic VX - Not great MPG
Originally Posted by paulhale View Post
Man, that still just seems way too high. I was nervous getting mine to 45 psi. Guess I'm just oldschool. I'm used to following the sticker in the car's doorjamb, so going much over 30 psi just sounds crazy.
I wouldn't worry about it... tires are far more likely to burst due to low pressure than from high pressure. The reason for this is that tires with too low of pressure will flex and deform too much causing them to overheat and in the worst case disintegrate and burst. Another benefit of higher pressure is that if you hit a curb and destroy your tire, you'll at least protect your rims. Brand new tires have been burst tested well over 300psi with usually the tire rims failing before the tire failing.
SMS Problem kernk Fuelly Web Support and Community News 2 02-27-2011 09:36 PM
Solar Powered Ventilation? swng General Fuel Topics 20 08-12-2009 05:28 PM
Crackling Exhaust Roar shatto General Discussion (Off-Topic) 4 08-01-2009 09:02 PM
Why do pulse jets lose power at high speed? GasSavers_maximilian General Discussion (Off-Topic) 5 06-10-2009 08:05 PM
Minneapolis City limits vehicle idling to 3 minutes civic_matic_00 Automotive News, Articles and Products 10 06-15-2008 04:28 PM
