94 Civic VX - Not great MPG - Page 5 - Fuelly Forums
Old 08-02-2011, 10:04 AM   #41
add|ct's Avatar
Re: 94 Civic VX - Not great MPG
^Curious, is your PCV valve located at the breather chamber underneath the IM or is it mounted directly into the IM between the runners for cylinder 1 and 2?
'92 Civic VX, Canadian model
Old 08-02-2011, 03:22 PM   #42
paulhale's Avatar
Checked the MPG. I'm at 41.5 right now.
The latter.
paulhale is offline   Reply With Quote
Old 08-02-2011, 07:05 PM   #43
add|ct's Avatar
Interesting, what is at the breather chamber from underneath the PCV valve location that you have, pray tell?
I'm of the belief that 92 and 93 VX(depending?) perhaps have the valve at the breather chamber and only the hollow 90* elbow where you have your PCV valve located.
Old 08-03-2011, 05:35 AM   #44
paulhale's Avatar
My valve is inside of the 90 degree elbow. When you pull it off the grommet, there is a tiny spring-loaded plunger inside it.
Old 08-03-2011, 09:30 AM   #45
add|ct's Avatar
Hey, when you do your next oil change, do you mind pulling the breather chamber that the leads up to your PCV valve off? It can be removed with 1 bolt I believe and it's supposed to have some sort of 'baffle' system to keep actual oil inside the car and venting of fumes only escaping out via the PCV system back to the intake manifold and re-ingested/slowly recycled out of the exhaust.
I haven't pulled mine yet, but judging from the crud from the PCV valve on the VX models(like mine has) that have the valve seated right into this chamber location, it probably needs a good cleaning.
I'm going to change my oil filter mid Oil Change Interval(my current one) and while it's off it's easy to remove the chamber. Someone else on here asked me to do it myself before, but didn't at my last oil change. I'm actually wondering now if it's crud-filled and would affect running out the oil change to 7,500+ etc.
Old 08-03-2011, 09:41 AM   #46
paulhale's Avatar
I just did an oil change, so it would be a while.
SMS Problem kernk Fuelly Web Support and Community News 2 02-27-2011 10:36 PM
Solar Powered Ventilation? swng General Fuel Topics 20 08-12-2009 06:28 PM
Crackling Exhaust Roar shatto General Discussion (Off-Topic) 4 08-01-2009 10:02 PM
Why do pulse jets lose power at high speed? GasSavers_maximilian General Discussion (Off-Topic) 5 06-10-2009 09:05 PM
Minneapolis City limits vehicle idling to 3 minutes civic_matic_00 Automotive News, Articles and Products 10 06-15-2008 05:28 PM
