92 VX bad milage - Page 2 - Fuelly Forums
Old 05-18-2011, 01:35 PM   #11
Re: 92 VX bad milage
Theoretically a plugged catalytic converter could cause a major decrease in fuel economy. It happened on my 2008 Volkswagen and my fuel economy did NOT decrease much. As the blockage got worse, power decreased so severely that it almost couldn't be driven.
Old 05-18-2011, 01:51 PM   #12
imzjustplayin's Avatar
you had a plugged cat on a 2008 VW? how'd that happen?
Old 05-18-2011, 02:18 PM   #13
alright ill go with the tune up first and also will exhaust leaks make the smog fail? one thing i forgot to mention was that when i start the car in the mornings (cold start) i get a strong smell of gas like running rich thats what made me check the spark plug but they were normal.
to do list
*spark plugs* ngk ZFR4F-11 @.o44
spark plug wire
fuel filter
*pcv valve*
distri cap
distri rotor
alignment
tire pressure
ground wires
what more to do? also do the wire set has to be ngk or can i use bosh?
noender is offline   Reply With Quote
Old 05-18-2011, 05:11 PM   #14
another thing i forgot to ask whats the stock idle for a vx 750rpm? because mine is at around 300-400 it looks really low on the tach unless the tach isnt reading right...
Old 05-18-2011, 05:49 PM   #15
vx is very similar to hx civic both lean burn 5 wire o2,egr ports get plugged up and affect gas mpg,i know it did on my hx,Majestic honda.com has 30% off on honda parts it's ware i go for mine,I clean the egr ports every 100k or so,cover is under fuel rail.361,200mi and counting.msweatherhead
msweatherhead is offline   Reply With Quote
Old 05-18-2011, 06:15 PM   #16
vxdude's Avatar
Send a message via Yahoo to vxdude
thats where mine is at, after the valve adjustment i could drive on flat surfaces at 500-600rpms with no sputtering..
vxdude is offline   Reply With Quote
Old 05-18-2011, 07:41 PM   #17
to do list
spark plug wire
fuel filter
*pcv valve*
distri cap
distri rotor
alignment
tire pressure
ground wires
only use OEM recommendations... so if it's NGK and denso, stick with that.. use the exact sparkplugs they recommend and nothing else. Civics HATE it when you use anything but oem recommended parts.
Old 05-19-2011, 05:32 AM   #18
It may have been coincidence, or it may have been because of some experimentation I was doing with trying to rig up a kill switch.
An exhaust leak could make smog fail, but a noticeably rich smell will definitely make smog fail...you're smelling hydrocarbon emissions and the smog test is checking for that first.
Old 05-19-2011, 10:11 AM   #19
Op, check to see if your manifold is cracked.. in all likelihood, it's cracked, letting out gasses and either not letting the o2 sensor do it job or letting it do its job poorly.
Old 05-21-2011, 06:43 PM   #20
so i was fixing my front toe and i notice i have a second cat converter im thinking its a cat since it says "CATCO" .what do you guys think?
Which Saturn SL for the best MPG's Drahthaar General Fuel Topics 12 09-10-2010 02:07 PM
Why do pulse jets lose power at high speed? GasSavers_maximilian General Discussion (Off-Topic) 5 06-10-2009 09:05 PM
Tires and Airtabs oh my! kitcar Experiments, Modifications and DIY 5 07-19-2008 06:31 AM
Finally got some LRRs rh77 General Fuel Topics 4 10-03-2006 09:16 PM
