92 Civic VX stumbling/hesitation - Page 10 - Fuelly Forums
Old 09-27-2013, 01:44 AM   #91
I've had some hesitation with my VXs as well, one thing that helped me was that I noticed when filling up that the gas tank had vacuum. (big hiss when unscrewing the cap) Replacing the gas cap cured some of the stumbling. It's easy to test by leaving the cap fairly loose and driving around a bit.
gtr09 is offline   Reply With Quote
Old 01-20-2015, 07:49 PM   #92
Yes. I have gotten almost 15 gallons in my VX also.
The second VX I have doesnt get more than 10 though.
I also found out somewhere that some VX tanks were 14 gallon though.
I also found that NON Ethanol gas give you about 10-15 percent better MPG.
And its true that when the pump shuts off, most of the time you can get another 3-4 gallons in it. So that is important for mpg calculation to fill it until it starts to come out.
Also, I found that if the car is on a hill tipped away from the gas pump, that when filling it up you can get the almost 15 gallons in it.
Hard to find pure gas for cheap around Tallahassee though.
softciyVX is offline   Reply With Quote
FS: D16Y5 Head $100 Plus shipping (other y5 goodies for sale too)LOOK INSIDE!!!!!!!!! GasSavers_topher For Sale 2 08-08-2011 05:25 PM
Installed 195F Coolant Thermostat ... Reset ECU? cfg83 General Maintenance and Repair 13 04-06-2011 12:54 PM
Best $100 to spend on a 1980's amarican full sized car. GasSavers_Ryland General Fuel Topics 33 04-22-2008 08:41 PM
2006 Toyota Camry LE rh77 Car Reviews 0 01-24-2007 08:17 AM
Finally got some LRRs rh77 General Fuel Topics 4 10-03-2006 09:16 PM
