92 civic vx 29mpg ??help? - Page 3 - Fuelly Forums
Old 02-20-2012, 02:09 PM   #21
Re: 92 civic vx 29mpg ??help?
Originally Posted by Kendaddy126 View Post
I need to clean the EGR ports... not easy...
have you seen this?...http://www.gassavers.org/showthread....t=egr+cleaning
Old 02-20-2012, 02:09 PM   #22
amaterasu71's Avatar
Smile Re: 92 civic vx 29mpg ??help?
well everyone here is the latest... I installed the new o2 sensor , all the fluids and put the tires up from 26psi to 42(max 44) and wamo milage went from 29 to 47mpg the last fill up (all highway). Im thrilled, I just replaced the fuel filter (which when i drained the gas was filthy) so hopefully it gets better. My rpms still seem high as they are running 3000 strong at 70 2600 at 65 but i could feel the lean burn going into effect at 65 so as long as im getting over 45 i guess i wont question the mpg gods. the speedo needs a sensor as its all over the board sometimes but the tach seems to register idle correctly so who knows .. Ill keep you informed as to my next fill up mpgs , thanks guys...
amaterasu71 is offline   Reply With Quote
Old 02-20-2012, 02:11 PM   #23
oh yea the shift light still tells me to shift in 5th gear ??? strange?
Old 02-20-2012, 05:15 PM   #24
add|ct's Avatar
^You have a non-VX/CX transmission.
The 'feel' at 65mph with your stated 2600 RPM is the vtec engaging for more power/more fuel consumption.
The VX transmission has lean burn primarily from 1,500 rpm - 2,200/2,300 RPM or so.
This means, you would probably be getting another 5-10 mpg 'potentially' out of this car on the highway with the original transmission.
'92 Civic VX, Canadian model
Installed 195F Coolant Thermostat ... Reset ECU? cfg83 General Maintenance and Repair 13 04-06-2011 12:54 PM
Best $100 to spend on a 1980's amarican full sized car. GasSavers_Ryland General Fuel Topics 33 04-22-2008 08:41 PM
2006 Toyota Camry LE rh77 Car Reviews 0 01-24-2007 08:17 AM
Finally got some LRRs rh77 General Fuel Topics 4 10-03-2006 09:16 PM
