'89 CRX HF + D15Z1 troubleshooting... - Page 10 - Fuelly Forums
Old 05-15-2011, 06:53 AM   #91
Re: '89 CRX HF + D15Z1 troubleshooting...
http://en.wikipedia.org/wiki/Calcium_Lime_Rust
Its ingredients include water, lactic acid, gluconic acid, glycolic acid, sulfamic acid, citric acid, and surfactants.
Mostly harmless...I bet it's fine for aluminum.
Old 05-15-2011, 11:30 AM   #92
imzjustplayin's Avatar
Well I'd definitely not call it "mostly harmless" since it is capable of seriously hurting you if you don't wear gloves while using it.
Old 05-15-2011, 02:24 PM   #93
MakDiesel's Avatar
Eh, the EGR's bolts are destroyed...they won't budge & nothing will grip them beyond an infant's strength to turn them. I PB Blastered them overnight but they are too far gone. In other news the IACV clicks fine w/ supplied 12v & back when disconnected. My thought would be to drill/grind the nuts off if I have to but the one closer to the fuel rail is a tight space for sure. I'd have to drill the bolts out completely and use a hex bolt/new nut combo to tighten her back down. Never used CLR for car-related stuff.....
'85 CRX Si Original EW3 @ 254k...suck it Detroit
'89 CRX HF-Z1 ~ When haste is needed
'97 Civic DX Hatch ~ Formerly 600hp, now 0hp, soon 115hp.
MakDiesel is offline   Reply With Quote
Old 05-15-2011, 02:47 PM   #94
GasSavers_Erik's Avatar
As a last resort, I sometimes use a hammer and long thin chisel on rounded off nuts to spin them loose.
The chisel needs only to be moderately sharp and you need to angle the chisel as much as possible to get it to rotate but not so much that you end up carving off chunks of the nut.
If you have a welder and enough clearance, you can sometimes place a large nut over the rounded nut and weld the two together.
Old 05-15-2011, 03:19 PM   #95
MakDiesel's Avatar
I'll try the chisel method, I don't have a welder handy, it would come in handy on days like today.
Old 06-09-2011, 11:49 PM   #96
MakDiesel's Avatar
***update***
Never got the EGR off and the nuts are now officially mutilated. Once I reset the idle w/ a bias towards high (we're talking 50-75 RPM max) she cleared up most of her gremlins that are idle related, still have noticeable rev in neutral overrun. I have to focus on house related crap now so I may lay off smoothing her out til I get some extended top hats to lessen the Eibach Sportline thunk. Thanks everyone, Mak
Old 11-23-2011, 03:43 PM   #97
Lots of info- thanks a lot all!
BTW "The PCV valve is new, and with the straight-through VX design I don't see how it can fail, it's just a hollow elbow."
Maybe important for some - the elbow is not the PCV. The PCV is located under intake manifold (hard to reach but possible when you put your whole arm between firewall and intake manifold).
Cheers!
yato is offline   Reply With Quote
Old 01-03-2012, 06:33 PM   #98
MakDiesel's Avatar
one of these days I'll get a video of the "fickle Shift light". Below 2k and usually in 3rd gear up a decent hill, the shift light will flicker like an old fluorescent bulb until it builds enough RPM's and decides to stay on solid green. Still has neutral rev overrun, but the original cruise/buck issue is much smaller at the moment.
Old 01-12-2012, 04:42 PM   #99
MakDiesel's Avatar
I should have done this one post #1...better late than...
This is "cruise/buck".
http://youtu.be/rLj6wmSDDRc
This is "fickle shift light".
http://youtu.be/EJCU98uB-ik
I believe these problems are related. Any suggestions?
Thanks,
Mak
P.S. Is there a way to embed these videos?
Old 01-14-2012, 02:22 PM   #100
MakDiesel's Avatar
I've created a new thread just for videos, as this thread is too long for some attention spans...
Why not add location to fuel ups? T5i Fuelly Web Support and Community News 11 07-12-2014 11:55 PM
Filter by Imperial vs. U.S. Gallons? bvz2000 Fuelly Web Support and Community News 4 05-02-2013 08:33 PM
Using a multimeter as a cheapo scangauge? ZugyNA Hypermiling 2 07-30-2007 07:05 AM
VX Head Question GasSavers_scostanz General Maintenance and Repair 8 02-17-2007 04:27 AM
