88 CRX; check eng light after trans swap - Page 2 - Fuelly Forums
Old 12-23-2008, 02:57 PM   #11
Grumble Grumble.... The side play on the trans sounds like a telltale. I'm used to VW transmissions, which are supposed to have quite a bit of slop in the input shaft so I didn't concern myself with the end play.... How much is normal? 1/8"? 1/16"? Less?
GasSavers_Hal9000 is offline   Reply With Quote
Old 12-23-2008, 03:05 PM   #12
Send a message via AIM to molecule
none...
1/32-1/64" i would say is normal...
1/16-1/8" is on its way out and will start making noise
1/8-1/4" major failure and can cause gear tooth damage
BE ZEITGEISTED
molecule is offline   Reply With Quote
Old 12-23-2008, 04:01 PM   #13
well, at least I know where the guy I bought the trans from works. He said that if it was bad he'd make good. We'll see.....
Old 08-24-2011, 03:12 PM   #14
Re: Play in input-shaft-bearing (VX)
Hi, Molecule. Tried to PM you, but couldn't see the option. I'm a new member, here, but noticed in some of your old posts that you had a trusted (and affordable) tranny-rebuild guy. My VX trans has input-shaft bearing noise, and probably has end-play/slop (still in the car, but my original VX trans was pulled at 167K with >1/2" of slop and incredibly still shifting all gears!). I am not qualified to rebuild the trans by replacing bearings, so I'd love to buy an affordable rebuilt CX/VX/HX trans (I included HX as I have 14" HX rims on the VX Civic). Live in the SF Bay Area, CA Thanks!
Originally Posted by molecule View Post
any play in the input shaft is wrong...and i'm sure your input shaft bearing is bad...they should be very tight...no play...
this requires the tranny taken apart
also you wont see any metal bits in the oil because all honda tranny's have a magnet...
willtech4food is offline   Reply With Quote
Old 08-24-2011, 07:05 PM   #15
Re: 88 CRX; check eng light after trans swap
i've got a rebuilt vx trans here
but i would need your busted trans in return.
BE ZEITGEISTED
MPG versus air temperature and Altitude MensaMike General Fuel Topics 6 06-21-2011 06:16 AM
Wool tuft pics and video on my Volvo 855 855R Aerodynamics 7 05-27-2008 01:14 PM
Is there any hope? pmistel Aerodynamics 29 06-24-2007 10:20 AM
E-85 and EPA rating zpiloto General Discussion (Off-Topic) 7 09-26-2006 07:04 AM
Any ideas how to install this? Compaq888 General Maintenance and Repair 0 12-21-2005 01:46 PM
