4 year old impact wrench is losing force- any repair options? - Page 2 - Fuelly Forums
Old 12-19-2008, 08:16 PM   #11
GasSavers_Erik's Avatar
Originally Posted by R.I.D.E. View Post
Intentionally liquid lock a cylinder to keep the engine from turning over when you get a really nasty crank bolt.
regards
gary
I've never heard of that- but it sounds easier than the rope trick- just pour oil in the spark plug hole and fill up the cylinder then reinstall spark plug?
Old 12-19-2008, 09:19 PM   #12
If you don't time the stroke correctly you could end up shoving all that oil into the exhaust or the intake...I have the fortune of having it happen
So basically you'll want to find TDC on #1 then go backwards about 1/8 stroke before filling...but totally at your own risk! I'd personally find another way.
PS My crx almost lifted itself off the jackstands and blocks using the starter motor/breaker bar method!
Daveedo is offline   Reply With Quote
