y5 in the making - Page 2 - Fuelly Forums
Old 04-13-2008, 11:39 AM   #1
y5 in the making
Welcome to my build
When I originally wanted to build a Honda I wanted more power without sacrificing economy and maybe even approve upon it. Even though many said they are inversely proportional I choose to disagree. I originally wanted to build a jdm d15b with 3-stage vtec. Doing research on the 3-stage vtec I discovered the usdm vtec-e, the d15z1, d16b5 (gx) and the d16y5. In the beginning my noobness led me to believe that there was no aftermarket support for these little engines. Well more research and a few phone calls opened up a new world of opportunities. I realized that no aftermarket parts were listed because there is minimal, or seems to be minimal interest in the engines in the general honda world.
Knowing that I could build a y5 to my hearts content I set out to find one. I was able to pick one up semi-locally for $250 which may seem high but at the time it was way cheaper than jdm importers and it came with many extra parts. I first was going to swap it in right away, throw on some bolt-ons and call it a day. But, my ?slight interest? turned into an obsession with the y5 build.
I first looked for a cam and was unable to find one. I was lucky enough to contact a very helpful guy in California who informed me for vtec-e to engage the base circles of the intake lobes must be the same. Knowing this I contacted Bisi upon the recommendations of others and he said ?No problem?. I described what I wanted out of my car, power with fuel economy in mind, so we decided upon a level 1.5.
So now that the power house was on it?s way I decided it would be nearly impossible to swap in to my car while having something to drive to school and work, so I begun to look for a shell to swap into preferably a hatch or coupe. I lucked out and a friend sold me the 97 ex in the pictures below for $300. Yeah cheap I know. When I got it, it wasn?t running. Well a cleared code later it started right up and has ever since.
Thanks for reading and here it goes!
Things I already have in Bold
Engine/Transmission:
D16y5 head
-P&p?d
-5-anlge valve job blended together
-Stainless valves
-Bisi level 1.5 cam
-Bisi cam gear
-Stiffer spring (not beehives)
-Factory roller rockers except secondary intake valve follower
-D15z1 valve cover
-D16z6/z1 dizzy. Still need jumper harness
-240 injectors
-Fuel rail
-Manual y5 IM with egr block off plate-Cheap C.A.I.
-still undecided on compression 10:1 or 10.3:1
D16y5 Block
-Stock crank, rods and p2m pistons
-P2m pistons have been ceramic coated
-O.E.M Honda bearings and thrust washer
-New water pump
-Endyn upgraded oil pump for y engines
-Arp rod bolts
Exhaust:
-Heat wrapped Hedmann Chikira
-2? pipe to rear c Flowmaster
Transmission:
Bone spec
-Dx/lx 4.058 FD
-Stock 1st and 2nd
-Zc 3rd and 4th
-Hf 5th
-13lb flywheel balanced to nascar specs soon to come
-Probably going with a Sachs Clutch
ECU:
-Chipped and tuned by Amkrew
-obd2a to obd1 harness by rywire
Suspension:
-Lowered about 2"
-Homemade strut tower bars on the way
Body/Exterior:
-Homemade black housing headlights TU:
-15? Konig heliums
-Maybe a lip
Interior:
-factory. except I removed sound detoninga and bulk head blanket.
Aerodynamics:
Since this is a project car I believe it should serve as a learning tool for others and I. And everything in this category is a maybe.
-Smaller mirrors
-Grill guard (well I havn't seen a tastful one yet please inlighten me)
-I was also wanting to reduce drag on the rear bumper by making my own diffuser via either two elongated holes about 3? high that cross the span of the bumper with about a 2? gap in between. Or three elongated holes that mock the shape and angles of the taillights and the license plate holder also only about 3? tall.
Well for those of you who read through this I would like to thank you. Any constructive criticism or input is greatly appreciated.
Thanks,
Chris
UPDATE: I was going to use the two door as my swap candidate but, decided that if I choose the 4door.
Reasons:
Clutch is almost brand new and still has lots of life
Flywheel has already been lightened
No manual swap required
Plus by doing the swap to the four door it will save me lots of time and money and I will have time to get it done right.
4 door has a rod knock so it's already broke.
This is the new contender
[/QUOTE]
GasSavers_topher is offline   Reply With Quote
Add an "ignore fuel up" feature MD1032 Fuelly Web Support and Community News 5 03-03-2012 10:48 PM
Notes Request earwhiskers Fuelly Web Support and Community News 2 07-20-2009 03:38 AM
City/ Highway kickflipjr General Fuel Topics 15 03-31-2008 09:50 PM
engine start / stop button question lunarhighway Experiments, Modifications and DIY 26 09-26-2007 06:58 AM
idle warm-up experiment MetroMPG Experiments, Modifications and DIY 37 03-10-2006 11:36 AM
