Wouldn't it be better to have a valve cover breather rather than having a tube going from the valve cover back to the intake??? - Fuelly Forums
Old 02-17-2006, 10:55 AM   #1
Compaq888's Avatar
better for the engine to have a valve cover breather and a breather on the intake??? Also would this create a vacuum leak?...
Would it be better for the engine to have a valve cover breather and a breather on the intake???
Old 02-17-2006, 11:00 AM   #2
Matt Timion's Avatar
I'm thinking it will create
I'm thinking it will create a vacuum leak. It's also bad to remove this because you won't be able to expell the oil particles in the crankcase, which will hurt your engine in the long run.
If you really want to prevent the oil from re-entering the engine through the intake, install a catch-can inline with the crankcase ventilation and the PCV line.
Old 02-17-2006, 11:05 AM   #3
Valve cover breathers
Breathers were common 40 years ago, but they were phased out to reduce crankcase emissions which, as I remember, were very significant.....about 30% of total uncontrolled emissions. Adding a breather and removing the PCV valve would be VERY bad for the environment.
The simple breathers were replaced with PCV valves. The PCV valve keeps the crankcase relatively free of water vapor, and the oil last slonger and there is less engine corrosion.
I vote to leave the PCV in.
Old 02-17-2006, 11:09 AM   #4
Yo tambien. Creo que el medio ambiente es mas importante que su coche de mierda.
Old 02-17-2006, 11:45 AM   #5
Compaq888's Avatar
Re: Valve cover breathers
What the hell are you talking about??? Nobody mentioned anything about a PVC. I said valve cover. You know the hose that goes from the valve cover to the intake. That one.
Old 02-17-2006, 11:51 AM   #6
Why such hostility? I don't know how you're going to get people to help you if you're always rude to them.
Old 02-17-2006, 11:53 AM   #7
If I remember correctly the
If I remember correctly the hose that goes from the valve cover to the intake is the pcv line.
Old 02-17-2006, 11:55 AM   #8
Re: If I remember correctly the
That would be incorrect, but it's a very common mistake. No need for anyone to be all hostile over a common mistake.
Old 02-17-2006, 12:03 PM   #9
The pcv line has the
The pcv line has the charcoal canister on it already, right? Squarey looking black thing on the b2?
Old 02-17-2006, 12:09 PM   #10
FE nut
diamondlarry's Avatar
It seems to me that I've heard that the hose being discussed is used for some type of a balancing effect for the PCV system. Is this correct?
2007 Prius,
Team Slow Burn
