02-17-2006, 05:20 PM
#21
Ok, I researched it more and
Ok, I researched it more and the jar is suppose to go between the PVC and the intake manifold. The flow of the air is toward the intake manifold, away from the PVC. I'll go return the fittings and put this bad boy inline with the PVC.
02-17-2006, 08:05 PM
#22
Re: Sweet, you just went to home
Originally Posted by SVOboy
Sweet, you just went to home depot and went to the air compressor section and there it was?
Exactly. I'm actually going to a hardware store in a few minutes to get a set of fittings.
Read the DIY in the DIY section about this puppy.
02-17-2006, 08:38 PM
#23
I will do this soon. Right
I will do this soon. Right now my money is occupied since I just bought vx rimzzz!
02-17-2006, 08:50 PM
#24
It Works
As usual, I'm joining the convo late, but...
The breathers are known for causing excessive oil consumption, and have become a popular add-on lately, mostly for looks -- not recommended.
I've been using the PCV catch tube for about 2 months (the one that's posted on here in the DIY section). It's less than 10-bucks at the hardware store. So far, I haven't emptied mine, and it's half-full of crud. Makes you think about what the PCV dumps back into the system.
02-17-2006, 10:18 PM
#25
I'm going to install it as
I'm going to install it as soon as I can get the car lifted.
rh77 you got any pics of your setup?
02-18-2006, 04:08 AM
#26
crud
shouldn't there be less of that crud in the breather if you run acetone to burn the gas better and thus keep the oil cleaner?
02-18-2006, 07:00 AM
#27
FE nut
Re: crud
I would probably say yes and no. The acetone will probably make for a more efficient burn but if the rings are bad and there is a lot of blow-by that could cause a bunch of breather crud.
2007 Prius,
Team Slow Burn
02-18-2006, 07:31 AM
#28
rings
My brother was saying the other day that the rings and pistons are so tight in the newer cars that the oil stays very clean even when it is time to change it. If you guys are pulling engines all the time - bust the glaze in the cylinders and if needed pop in a new set of rings. Makes all the diference in the world.
02-18-2006, 07:34 AM
#29
You can buy catch cans off
You can buy catch cans off ebay for $25 shipped. I was thinking about getting one.
Ebay Link here
2008 EPA adjusted:
02-18-2006, 08:04 AM
#30
FE nut
Re: You can buy catch cans off
Ebay Link here
That's not a bad deal at all. You can't hardly mess with building one for the price shown; even if you have to pay the full $10.99. I'm going to Walmart today to look into the Campbell Hausfield air filter and, unless it's significantly lower priced, I'll come home and order one of these. What is the tube that runs down the side of the Ebay unit?
2007 Prius,
Team Slow Burn
