Would you buy a 92 Civic CX with a blown head gasket??? - Page 2 - Fuelly Forums
Old 10-10-2007, 09:34 AM   #11
Danronian's Avatar
As long as the oil doesnt look like a chocolate milkshake, the bearings in the bottom of the motor should be fine. If the oil does look terrible, your bottom end might be garbage too. Hopefully you can get away with just replacing the head gasket, and shaving the head for straightness.
Old 10-10-2007, 10:35 AM   #12
smccall's Avatar
ok, when I check it out, I will look at the oil and the spark plugs to see if there are any issues. I'm hoping its just the head issue. What is a Honda SX?
Old 10-10-2007, 11:02 AM   #13
GasSavers_TomO's Avatar
I think he meant the Si model. That is the 1.6 liter motor that uses a three layer head gasket. basically a layer of metal sandwiched between two layers of rubber, it makes for a great seal.
For the $800 price tag, if the bosy is in decent shape then I'd go for it since It would cost less than $50 to replace the headgasket myself. Of course, if the head needs work, it would be more than that.
Honda Civic VX Info/Links
Old 10-10-2007, 11:09 AM   #14
panamacolin's Avatar
post some pictures of the car...goodluck!
panamacolin is offline   Reply With Quote
Old 10-10-2007, 01:06 PM   #15
smccall's Avatar
Yeah the body is in good shape with only some scratches and a small dent in the hood. The driver's seat has some rips, but thats about it. I'll post the pics I got of it.
Old 10-10-2007, 01:49 PM   #16
Junior Mint
dogncatboy's Avatar
I'm begining to believe that this was a standard feature!
... D'oh!
dogncatboy is offline   Reply With Quote
Old 10-10-2007, 09:40 PM   #17
Member
78si's Avatar
Complete engines are cheap. Find a JDM engine importer.
78si is offline   Reply With Quote
Old 10-11-2007, 10:10 AM   #18
smccall's Avatar
yeah 78si, I think that would be the best way to go. The engine already has 175k on it. Speaking to a few Honda repair shops, two said they would only do an engine swap, 2 said if you do the top end, eventually you will have to do the bottom end, and I gave me a price of $800 to replace the gasket and resurface or mill the head. I would be better off saving a bit more money and finding one with no major engine issues so I'll pass on this one. Almost had one.
Old 10-11-2007, 03:16 PM   #19
Member
78si's Avatar
I can help you locate an engine. CX or VX
Old 10-12-2007, 05:34 AM   #20
GasSavers_Ryland's Avatar
head gaskets shouldn't blow on their own, look for other problems with the car that show signs of abuse and fix them.
The power of manifestation....... BumblingB General Discussion (Off-Topic) 12 06-06-2007 06:03 AM
Concentrating photovoltaics advancements ... cfg83 General Discussion (Off-Topic) 4 03-01-2007 06:24 AM
Just got my '95 VX whychug Introduce Yourself - New member Welcome 7 01-30-2007 06:24 AM
Poll: Should Stability Control be Standard rh77 General Fuel Topics 14 09-30-2006 09:44 PM
Extreme hybrids are technically feasible: Sludgy Electric and Solar powered 1 05-10-2006 11:32 AM
