Would seafoam help clean this (pic inside)? - Page 2 - Fuelly Forums
Old 03-04-2008, 05:23 PM   #11
With that many miles, I'd just keep doing regular oil changes, until the engine needs to be replaced. With that many miles and as much gung as their is, the only way your going to fix it is to rebuild it, but you might as well get as many miles from it, as possible.
Old 03-04-2008, 09:58 PM   #12
Wire brush and kerosene, then suck it all out. ARX will probably work for you, but if you can get that stuff off, it will give whatever cleaner you choose the chance to work on something else.
Old 03-05-2008, 09:04 AM   #13
Accutally a small wire brush and a vacuum cleaner as you brush it off would probably work the best then take a sample of the gunk and try different solvent/engine flushes to see which will work the best on any left in the engine before you dump the flush in so you will know if it completely dissolves it before you use it.
Old 03-05-2008, 11:00 AM   #14
rpm
Thanks for the input everyone.
I don't use this car much at the moment (only weekend drives and such), it does something like 2500 Km a year. It's hard for me to understand this condition since I serviced it as per the owner's manual since new.
Maybe I should just drive it as is, for fear of making things worse?
I will research more on Auto-Rx and high mileage oils though, thanks for the links!
edit: Read a lot of positive reports on Auto-Rx but it would take me more than two years to do the required 2500 miles clean and 3000 miles rinse cycles!
rpm is offline   Reply With Quote
Old 03-05-2008, 06:24 PM   #15
gto78's Avatar
Originally Posted by RPM View Post
...It's hard for me to understand this condition since I serviced it as per the owner's manual since new...
Vehicles that aren't driven actually have a worse life than vehicles that get used all the time. After you drive it and park it, it will cool off and then the hot air inside the engine turns into condensation which the forms a surface layer of rust. If the engine doesn't get used for a long period of time then the oil that was clinging to the inside walls of the engine starts to migrate to the bottom leaving the metal completely unprotected to humidity. The longer it sits the more rust is formed. Then the piston rings get stuck in one position inside the pistons. When you attempt to drive it again, all the piston rings are stuck and allowing the combustion process to blow right past them. This turns the oil black almost immediately. Next problem is all the rust being mixed into the black oil and then pumped throughout the engines oil ports etc. It all churns up and mixes into a black gooey mess.
Parking a car is really abusive, and if the car is parked for a long time (ie: over a month) you should start it and let it warm up, then immediately change the oil. NOONE ever does this, including myself- but in a perfect world...
gto78 is offline   Reply With Quote
Old 03-05-2008, 10:04 PM   #16
Danronian's Avatar
With that many miles, I would just let the motor be on the inside until it needs to be taken apart and rebuilt.
Old 03-06-2008, 08:16 AM   #17
ITS THE OIL MAN ! ! ! IT MAKES THE SLUDGE ! ! ! YOU ALL HAVE BEEN FOOLED into thinking that it is the way you are driving the car that forms the sludge but it all comes from the oil!!
OK that said I have to ask what brand of oil have you been using and the temperature of your thermostat in the engine.
Old 03-06-2008, 09:39 AM   #18
gto78's Avatar
Originally Posted by JanGeo View Post
ITS THE OIL MAN ! ! ! IT MAKES THE SLUDGE ! ! ! YOU ALL HAVE BEEN FOOLED into thinking that it is the way you are driving the car that forms the sludge but it all comes from the oil!!....
Don't get so excited man, calm down. LOL We're just having a friendly discussion, nothing too serious. I have my own experiences, and my own examples over the last 19 years of rebuilding engines, racing cars, etc. Everyone else has their own opinions and experiences also.
Your also right- the sludge comes from oil, but it's also caused by a combination of driving habits and cheap oil. Sludge is formed from oil that is burned/overworked/full of carbon etc. A quality oil will not lose it's viscosity as quickly when exposed to those conditions. However, some oils have less detergents and fail to remove carbon and soot from cylinder walls, so they stay cleaner "looking" and appear to last longer while the engine is filling itself with crud.
So in a case where the engine is not used much, you can't get away with cheap oil.
Old 03-06-2008, 11:32 AM   #19
rpm
I believe it was Castrol GTX 10W40 for the first ten or so years. Changed it every 6 months.
Lately I've been using Ford's own 10W40 semi-synthetic blend.
This car uses a 88 C (190 F) thermostat but due to ignorance, it was stuck in the open position for many a year.
Old 03-06-2008, 11:58 AM   #20
ive been using castrol GTX in my vehicles and ive had the valve cover off both of em and they look new, just have some brown burnt on oil stains.
Full tank of fuel or not? elvyn General Fuel Topics 9 03-24-2010 11:53 PM
deep cycle battery for starting a metro? skewbe General Maintenance and Repair 9 08-12-2007 02:12 PM
More need for computer help Rstb88 General Discussion (Off-Topic) 2 01-31-2007 07:30 PM
Made the top 10 first tank, now what? GasSavers_Kraig General Fuel Topics 16 08-28-2006 05:56 PM
