Why is my idle high? - Fuelly Forums
Old 08-16-2007, 03:18 PM   #1
I have a 1993 HOnda Accord lx coupe.
When I turn my car on in the morning to go to work, my idle is usually at 2000RPM. Once the engine has been running and I stop, it's back at 600-700 and isn't rough at all. Why is this?
phantomcow2 is offline   Reply With Quote
Old 08-16-2007, 03:42 PM   #2
Mentalic's Avatar
The higher idle is to warm up the engine and emission control components quickly. Normally it only lasts a minute or so.
Mentalic is offline   Reply With Quote
Old 08-16-2007, 04:09 PM   #3
|V3|2D
thisisntjared's Avatar
hondas have 2 valves to control idle. one while the engine is warm and one while the engine is cold.
when the one that controls the cold idle wears out it lets the idle creep. the good news is you can just tighten it. the bad news is i dont know how it works on accords, but people on honda tech do. i wouldnt think it would be too different from civics...
the bottom line is this link might help:
http://www.honda-tech.com/zerothread?id=1003988
Old 08-16-2007, 06:10 PM   #4
Well It's functioning properly then. It does go away as soon as the engine is warm, so after a couple minutes.
Old 08-16-2007, 08:02 PM   #5
Hockey4mnhs's Avatar
you could put in a engine block heater so it goes away even faster and it could get you better fe.
Old 08-16-2007, 08:12 PM   #6
I may do this for winter.
Old 08-17-2007, 11:20 AM   #7
How much is an engine block heater. How long does such a device take to heat up an engine? and how difficult and time consuming is this to install. Im thinking this might be a useful mod before the winter.
Im very curious.
GasSavers_StanleyD is offline   Reply With Quote
Old 08-18-2007, 09:00 AM   #8
Im very curious.
My father is driving an old Mercedes Benz Diesel, and we live in NH (cold in winter!). WHen he gets up and leaves at 6AM, he could never get it started on a cold morning without the block heater to help. He has it on a timer so that it turns on 30-60 minutes before he leaves, and it starts right away. So I think 30 minutes is all it takes.
There's a whole variety of these heaters available, some are easier than others to install.
Scangauge gets website upgrade ketel0ne General Fuel Topics 1 08-10-2006 05:52 PM
Make the page lengths 30 posts again, please SVOboy Fuelly Web Support and Community News 4 05-18-2006 12:43 PM
