While I have the valve cover off... - Fuelly Forums
Old 10-22-2010, 04:16 PM   #1
slogfilet's Avatar
This weekend, I was planning on adjusting the valves on my VX for the first time. While I'm at it, I will check (or replace) the timing belt/tensioner and water pump.
Anything else I should do while I'm in there? I'd like to not have to open it up again right away; I'll be replacing my rather leaky valve cover gasket.
What other preventive maintenance items can be taken care of with relatively little special equipment? I might add this is my first time in an engine, but I'll be taking my time (and I have the Helm's manual.)
(On a side note, I think my input shaft bearing is bad. It might be a while before I'm able to drop the tranny for that one.. anything else I should do while I have THAT out? Rear main seal, etc?)
slogfilet is offline   Reply With Quote
Old 10-22-2010, 06:52 PM   #2
Lean Burn Mode
pgfpro's Avatar
Re: While I have the valve cover off...
Sounds like a great maintenance program. One other thing I always like to suggest is have the injectors clean and flow tested.
Old 10-26-2010, 11:45 AM   #3
slogfilet's Avatar
Ended up going pretty well... the old gasket was very brittle and actually broke when I pulled it out.
About half the valves needed adjustment... I used a 10mm wrench and a screwdriver, but I can see how the "valve lash tool" could be a big help. I had to do a couple valves more than once when the screw went out of adjustment as I tightened the jam nut.
I also did a compression test... 190 across all four cylinders! Though it did take a good 10-12 cranks to get up to pressure.
issue with image in signature banner brian83 Fuelly Web Support and Community News 5 09-13-2010 04:33 AM
Am I crazy for thinking like this? imzjustplayin General Discussion (Off-Topic) 24 10-19-2008 08:53 PM
GasSavers.org Stickers - Cheap - $4.50 shipped/pair - any color SoAngel For Sale 0 07-12-2008 10:06 AM
Timing chain and FE bowtieguy Experiments, Modifications and DIY 22 11-11-2007 09:48 AM
Driving Less Saves Gas kickflipjr General Discussion (Off-Topic) 10 02-09-2006 01:56 PM
