Which tranny for my vx swap - Fuelly Forums
Old 08-15-2008, 09:54 AM   #1
I am placing a d15z1 in my 89 dx. I was pondering changing the dx tranny for the cx/vx that actually belongs to this engine, but they hard to come by for a decent price. I have access to a crx hf tranny, i do not know which one it is though. Would my dx tranny run the rpm's too high if I just kept it, and also, would the hf gears be a bit too long and make my pickup speed suffer greatly? While I'm asking questions, will the hf tranny fit the z1 and my hatch with my current mounts?
hunterhound is offline   Reply With Quote
Old 08-15-2008, 10:59 AM   #2
Danronian's Avatar
If you were to install the z1 trans into the 89 hatch, it does have a different front engine mount and the clutch is operated with a hydraulic system whereas your 89 civic uses a cable operated clutch. All of this can be custom made, but that is a lot more work to add to the swap.
I can't be of much help with the gearing differences since I seem to have misplaced the link I had comparing the different gearing for the different d-series trans.
Old 08-15-2008, 11:23 AM   #3
Danronian's Avatar
Just found the gear ratio lists I had lost.
http://www.geocities.com/bing_bong916/trannyspecs1.html
Well I thought I found the one and copied the link wrong, but this should help. This was copied off of d-series.org, a very good source for reliable specs for Honda d-series trans.
Old 08-16-2008, 09:09 AM   #4
Member
Yes, the hf trans will fit your z1 with the stock trans mounts, thats what I put in my 90 hatch. Its probably your best option, cable clutch and ratios at least as tall as the original vx one. (I'm turning about 2k at 70mph) I'm very happy with mine. First gear is maybe a little taller than I would like, but the dx trans would rev too high IMO.
nowhhs is offline   Reply With Quote
Old 08-24-2008, 10:38 PM   #5
For simplicity's sake I would say that the dx would be fine. And if you feel your not getting the mpg's you would like you can always change it down the road.
Your swap might go smoother one step at a time.
GasSavers_topher is offline   Reply With Quote
Fix for a wonky Civic speedometer basjoos Experiments, Modifications and DIY 2 05-14-2012 07:31 PM
ICE loads basjoos Experiments, Modifications and DIY 9 11-11-2007 09:32 PM
Hey people: enter your location in your profile please MetroMPG Fuelly Web Support and Community News 7 02-18-2007 08:58 AM
