Where can I get cruise Control for a 1995 Civic VX??? - Fuelly Forums
Old 09-26-2007, 09:23 AM   #1
panamacolin's Avatar
Hi,
Just wondering if anyone has cruise control in there civic vx? wondering if you have a aftermarket cruise or if you got one out of an si or ex?
Thanks!
panamacolin is offline   Reply With Quote
Old 10-02-2007, 12:27 PM   #2
JCWhitney had one made by Audiovox (yes, the radio people). I have one fitted in my 1969 Saab Sonett. For under $100 (maybe $120 now) it was one of the best purchases I made. I'll soon be installing another one into a friends '65 Barracuda (225 w/automatic).
Old 10-02-2007, 03:07 PM   #3
yea they still have it. ive seen a few universal aftermarket units on cars and trucks at a local junkyard near me i was just about ready to yank one out when i noticed where the cable connects to the TB had been cut(engine was already gone) so that shot that idea out of the window
Old 10-03-2007, 08:20 AM   #4
DracoFelis's Avatar
If you want to go on the cheap, an (even less expensive) alternative to a "cruse control" is a mechanical (locking) hand throttle like I put in my CRX:
http://www.gassavers.org/showthread.php?t=4876
Pros:
It is cheap (under $35) to buy, and reasonably easy to install.
Unlike a cruse control, puts virtually no parasitic load on the engine, as it's all mechanical (and doesn't use electrical or other power to function, like a real cruse control does). The lack of parasitic losses for the controls, is a plus (vs a real cruse control) for FE.
This device makes it VERY EASY to accelerate slowly/smoothly, as you have much clearer feedback about your throttle position than your foot gives you. This is also good for FE.
You can easily switch back and forth between the hand throttle and the foot throttle. You can even use your foot to give you current hand throttle position a momentary boost (for climbing a hill, for example), as both throttle controls are hooked up all the time. So the one that "wins" at any given time, is whichever of your two throttles has the higher throttle position at that moment in time.
And the device makes it easy for you to lock a specific throttle position of your choice (i.e. a VERY EVEN "foot", as the mechanics stay in place)! This is also good for FE.
Cons:
The device maintains a constant throttle, not a constant speed. On level ground these are relatively the same (so the device works like a real nice "cruse control" on level ground). However, on hilly ground, I find myself constantly making minor changes to the throttle position (to keep my speed somewhat even).
And unlike a real cruse control, it will not automatically turn off when you step on the brakes (which could be considered a "safety issue"). However, this is mitigated by the fact that I have a manual transmission car. So if I somehow forget (in an "emergency") to turn off the hand throttle (i.e. push the lever all the way down), the throttle may still not have any effect on braking distance because: 1) If I have the clutch in (a common stick-shift driver reaction in an emergency), the throttle position doesn't matter for braking. It might "race the engine" more, but that would be it. and 2) And if I brake very fast "in gear" without pushing in the clutch, I'll likely "kill the engine" anyway. And throttle position also doesn't affect braking after the engine dies!
Average fuel mileage line in the history graph? BDC Fuelly Web Support and Community News 1 05-06-2009 12:07 AM
Available Members or New Team Formation rh77 General Fuel Topics 164 03-14-2008 02:07 PM
Volvo 240 High-MPG project car wins employee car show brucepick General Fuel Topics 8 06-26-2007 08:59 AM
Comparison of Gas vs electric zpiloto Electric and Solar powered 21 04-18-2007 06:09 PM
Is there a website where I can look up... wehrd1 General Maintenance and Repair 3 04-18-2007 05:23 PM
