Except when you use Synlube then even 5-6 psi is enough to keep the bushings lubricated . . . Miro didn't recommend that I install a mechanical oil pressure gauge because pressure would not matter when using Synlube since the lubrication is provided by the solids in the lube and not the hydralic pressure. Seems weird but it is working great so far.
Journal bearings are fluid bearings - there's no physical contact between components (from something like a ball and race bearing). They also rely on pressure to work as a bearing... Theoretically, you could run those bearings using high pressure water (much higher given lower viscosity)
The only time there's physical contact is during oil priming and startup (no or very little pressure). So if you had high flow, low pressure - they won't be working as bearings, and instead it will just be a lubricated shaft spinning in a cylinder :/
I'm not saying that solid lubricants are not necessary - I'm just saying that given a journal bearing with a properly functioning oiling system, there should never be metal to metal contact (where you'd want/need solid lubricant).
11/12
