I don't know the duration of the stock camshaft, but here are the lift specs.
Lobe lift intake .2626"
Lobe lift exhaust .2732"
Here are the specs from the camhaft that is currently in the car.
Intake: 284 degrees duration 0.432" lift
Exhaust: 274 degrees duration 0.417" lift
All these specs are based off of a 1.5:1 rocker ratio.
The low speed test was done in 2nd gear at 2,000 rpm. The high speed test was done in 3rd gear at about 1,800 rpm.
