Water Pump Replacement. - Fuelly Forums
Old 04-01-2013, 02:43 PM   #1
As a courier I drove my previously owned (used) 2006 Tundra between 150 to 350 miles a day delivering everything from envelopes to over 1,000 lbs of product to people on at-home dialysis.
Timing belts need periodic replacement so I had it done. As the front of the engine is removed to replace the belt replacing the water pump, pulleys, etc. is usually done.
The photos are of the engine block after 255,000 miles and the water pump with half that mileage, using distilled water (no minerals to build-up) and AMSOIL Antifreeze & Engine Coolant (ANT1G-EA), Dominator® Coolant Boost (RDCBCN-EA) .
https://lh5.googleusercontent.com/-w...8/DSC05560.JPG
https://lh6.googleusercontent.com/-q...8/DSC05556.JPG
Reckon that Amsoil stuff works.
Old 04-07-2013, 04:11 AM   #2
kamesama980's Avatar
I suspect that changing it occasionally helps. You know, preventative maintenance like you're doing. Most engines I've seen that have gunk built up either used tap water or hadn't changed the coolant ever on a 15-20+ year old engine.
-Russell
VX catalytic converter replacement slogfilet General Maintenance and Repair 9 11-22-2010 03:15 PM
Diesel-electric Insight? GasSavers_bobski General Fuel Topics 3 08-24-2009 11:49 AM
How to FE drive when OAT is hot? GasSavers_rGS Hypermiling 3 07-19-2007 03:35 PM
Memorial Day. Remember those who died for our country. CO ZX2 General Discussion (Off-Topic) 5 05-28-2007 07:42 AM
