vx wheels on a hx - Fuelly Forums
Old 07-16-2010, 04:57 PM   #1
vx wheels on a hx
Can anyone confirm that civic vx wheels will fit a civic hx? I just bought a hx that has steel wheels but I have a set of vx wheels that I would like to put on.
snakedelong is offline   Reply With Quote
Old 07-16-2010, 06:20 PM   #2
imzjustplayin's Avatar
Lulz! So you're telling us that you have the wheels to put on the vehicle you already own yet you don't know if it will work? Just try it! It'll be obvious from the get-go whether or not it will work. If it alleviates any concern, the 1996 Civic DX came with 13" wheels. Just try it and see if it fits, if it doesn't fit, take off the wheels but I think it will fit.
Also, I kinda want you to try this out because I too have been wondering as I have had no 100% confirmation that this configuration would work. (I'm interested in doing the same with my civic as well)
Old 07-17-2010, 03:24 AM   #3
It is possible for wheels to seem to fit but they don't really fit. It's still visually right there for you, but you have to know what you're looking for.
When you try them on, look for:
- Bolt pattern, obviously.
- Hub diameter; make sure it's the same and that they aren't loose on the hub before bolting them on (if the old ones weren't; hub-centric vs. bolt-centric).
- Make sure they go on all the way; you don't want them to bind on something and be sticking out, riding on the wrong part of the lugs and letting your drum brake rattle around behind the wheel. (This happened to me. Bought new wheels at a shop, drove home, wondered what that rattling was...)
- Make sure the lug nuts (or lug bolts, if equipped) have the same type and angle of shoulder, the surface where they mate to the hole in the wheel.
- Make sure the offset is the same, or be aware of the difference and decide if you accept it.
There may be more but that's what I can remember.
vx ball joint jmf General Maintenance and Repair 7 06-12-2009 04:03 AM
Electrorheology Leads to Efficient Combustion flapdoodle Experiments, Modifications and DIY 5 10-05-2008 01:45 AM
Can't add to my Gas Log? DarbyWalters Fuelly Web Support and Community News 7 01-26-2008 05:14 AM
STD cam a good idea in DX with HF transmission? StorminMatt General Fuel Topics 3 12-27-2007 04:10 PM
Diesel Kleen cetane booster diamondlarry General Fuel Topics 10 11-10-2005 01:27 AM
