VX Spark Plugs - Fuelly Forums
Old 06-11-2007, 06:06 PM   #1
mrmad's Avatar
VX Spark Plugs
I see that the Civic VX needs NGK zfr4f-11 plugs. What is so special about these plugs to mak the VX run in "lean burn" properly?
Old 06-11-2007, 06:36 PM   #2
jadziasman's Avatar
The VX and CX both use the same NGK spark plug. Don't know why the CX and VX would have this in common. Go to NGK's web site. Maybe an explanation lurks there.
Old 06-11-2007, 07:00 PM   #3
GasSavers_TomO's Avatar
You need a spark plug designed to take the heat of Lean burn, that is what the 4 is in reference to in the zfr4f-11 Here's a break down:
Z= Extended Gap type plug
F= 19mm (3/4") reach, 16mm (5/8") Hex Metal shell size
R= Resistor
4= Hot plug the range is 2-11 2 being hottest, 11 coldest (we need to hotter plug to stand up to the Lean condition)
F= Firing end construction (special design)
11= 1.1mm (.044") wide gap (wide gap like this is good for lean burn)
The CX is a swirl type combustion setup with 8 valves (swirl style allows for leaner A/F ratios) and that is why the CX and VX use the same spark plugs.
Honda Civic VX Info/Links
Old 06-11-2007, 10:08 PM   #4
Great info on the plug reading, you know everything!
Old 06-12-2007, 01:24 PM   #5
Thanks SVO, but I am just a sponge that spends many hours researching things on the intarweb and double-checking to make sure it's correct, lol. I've filled two 40Gig hard drives with documents, pdfs, and bookmarks of info, then I filled a 20Gig hard drive with MP3s to listen to while I search, haha.
Oregon-Washington: Winter gas ending, summer gas formula starting? 740dan General Fuel Topics 5 02-26-2013 10:17 PM
miles between fuelup limit? drnknmnky13 Fuelly Web Support and Community News 6 09-14-2010 04:08 AM
Automatically add the 9/10ths of a penny on to the gas price Saiyaman156 Fuelly Web Support and Community News 1 08-10-2008 02:23 AM
Drafting behind a Truck GasSavers_roadrunner Hypermiling 20 12-24-2006 12:17 AM
