VX Slow to Start - Fuelly Forums
Old 11-17-2008, 03:15 PM   #1
VX Slow to Start
I have a '95 VX that is in very good condition. It has roughly 150K miles and it historically has ran well. At the moment it takes 2 - 5 seconds to start cold, but starts right away once it is warm.
Any idea what would cause this? It used to start right away either hot or cold. Is there any known VX fuel or ignition problems that might cause this? My spark plugs have about 30K miles on them and the fuel system is original including the fuel filter. The battery has a little corrosion on the terminal, but still spins the engine over quickly.
Also, once the engine is started it runs great and the fuel economy is reasonable for a VX.
Thanks!
Wandering Albatross is offline   Reply With Quote
Old 11-17-2008, 03:16 PM   #2
What oil are u running?
In winter, a 5w30 would be the best choice, or even better, synthetic.
Old 11-17-2008, 03:20 PM   #3
I am using Mobile 1 synthetic 5w20.
Old 11-17-2008, 05:01 PM   #4
jadziasman's Avatar
Hey W.A.
You should try turning the ignition key on and wait for a couple of seconds so that the fuel pump can fully pressurize the line. My 92 VX starts very quickly each time I do this for temperatures between 0?C and 35?C. I have been doing this for a while now to reduce wear and tear on the 17 year old starter motor.
My guess is that the fuel pressure drops when your VX has been sitting for a while due to slight leakage of the diaphragm on the return line that runs from the fuel rail to the gas tank. You could test for this by installing a fuel pressure gauge on the fuel filter to see if the pressure is low when first starting the engine after sitting overnight.
Old 11-17-2008, 05:20 PM   #5
Originally Posted by jadziasman View Post
Hey W.A.
Beat me to it!
+1
regards
gary
Old 11-17-2008, 05:22 PM   #6
I'll try turning on the key and letting it sit for a second to see if that helps when it is cold.
Old 11-18-2008, 05:23 AM   #7
suspendedhatch's Avatar
You've stated that all your maintenance parts are old so why don't you replace them?
Replace the engine grounds. The factory grounds are barely adequate when new. Add in some corrosion and the two most noticeable symptoms are hard starting and rough idle.
Old 11-18-2008, 05:13 PM   #8
I have a 92 VX that had developed a similar hard cold start problem.
It turned out to be deteriorated piece of rubber fuel line in the fuel tank. This rubber fuel line goes from the pump to the pump mount bracket fuel line pass-through. Once I replaced the rubber line (cleaned tank and replaced fuel filter) everything was back to normal.
Might be worth a check if all else fails.
bjm206 is offline   Reply With Quote
Old 11-18-2008, 05:15 PM   #9
Danronian's Avatar
I agree that replacing the maintenance items is a great idea.
Wouldn't surprise me if simply the spark plugs are almost worn-out. I know my past two VX motors have quickly worn-out the OEM spark plugs I've used in them.
Old 11-18-2008, 05:22 PM   #10
well could be a number of things: corrosion build up/starter getting weak/dirty ground path(causes all sorts of issues)/just cold oil/ let the fuel pump prime first to build pressure back up.
Brakes 1993CivicVX General Fuel Topics 3 10-05-2007 03:27 AM
Wheel covers Telco Aerodynamics 6 05-27-2007 05:25 AM
For all you diesel luv3rs. omgwtfbyobbq Diesels 3 03-02-2007 08:28 PM
Cardboard box + duct tape = LxMike Aerodynamics 18 11-18-2006 10:53 AM
