VX shift light question - Page 4 - Fuelly Forums
Old 10-24-2007, 05:39 AM   #31
Junior Mint
dogncatboy's Avatar
Originally Posted by 1993CivicVX View Post
my shift light is pretty wonky too. I don't need it tho, do you? Shift by your speedo, not your tach, for best FE. On flat it should go something like this if you have the '92-'93 civic VX (I believe higher mph shift points on the '94 '95 VXes)
shift into 2nd gear at 12mph
shift into 3rd gear at 20mph
shift into 4th gear at 25mph
shift into 5th gear at 31mph
Now that my timing belt is on right, my shift points match yours. When the belt was off a tooth I couldn't shift at low rpms and get in to the high gears as fast. Word to any VX owners who aren't getting this kind of performance, it may be your belt. I've also noted that I can cruise up hills in a higher gear without lag and that my shift point has dropped from about 1700rpm to 1200rpm. Also when I cruise 60mph the rpms were at 2200 and now they are a smidge under 2000. Overall changing the belt position has made the car have better throttle response, lower shift points and better hill climbing ability.
... D'oh!
dogncatboy is offline   Reply With Quote
Tranny fluid flush for FE? brucepick Transmissions and Running Gear 27 07-25-2010 05:03 AM
Supermid Arrives! 88HF General Fuel Topics 3 06-23-2007 01:53 PM
GM: Petrol is Dead Silveredwings Automotive News, Articles and Products 6 06-12-2007 11:06 PM
Interesting SG2 observations. Compaq888 General Fuel Topics 8 05-06-2007 11:33 AM
"Lean Cruise" ECU Modification Thoughts GasSavers_scostanz General Fuel Topics 12 07-11-2006 04:36 AM
