Originally Posted by thisisntjared
175 isnt that bad at all, i meant something like 185-205. i should have specified newer civic wheels
LOL, and me running around on my 215/50/13s, shame on me. But I use the wider tire in my spirited driving events at the autocross as well as my daily commute. It helps me corner...at the event and on the streets, lol. Tire pressure is the key though. I'm running a minimum of 48psi in all the tires during my daily commutes, and on days that I have autocross events, I run it up to about 51psi.
Definitely check your timing to make sure it's spot on.
The upshift indicator (as Honda calls it) reads the MAP sensor, TPS sensor, and rpm signal to determine the best upshift timing.
The Rotor trick is really only good for making sure you have the spark plug wires in the proper order. The rotor contact area is wide enough for a 15° timing spread and isn't great for telling if the timing belt is set correctly. Best thing to do is:
- Take off valve cover
- Take off upper timing belt cover
- Take out the spark plug closest to the timing belt cover (#1 spark plug)
- Gently place a long thin screwdriver into the combustion chamber through the spark plug hole
- Rotate the crank pulley counter-clockwise until the single slash mark lines up with the TDC mark on the lower timing belt cover (Watch the screwdriver to help notice when the cylinder is at TDC)
- Check the camshaft pulley to make sure the "TOP" is at the top, and the angled mark on the lower left of the cam pulley is pointing at the plastic indicator on the inside upper timing cover.
With my 94 VX having over 336K miles on it....on a flat road and about 10% throttle, I will be in 5th gear by the time my speedo reads 30MPH. And that is with the upshift indicator illuminating to tell me to upshift as well. So when your VX is running right the same should hold true for you on a flat surface.
Hope some of this helps you out, dogncatboy.
I recently changed all of my vacuum lines with new 1/8th inch fuel line (bought fuel line by accident). But I found out that the fuel line fits more snug than the vacuum line and resists collapsing better. Vacuum line is cheap, and definitely worth the 1 hour (at most) it takes to replace every bit of it under the hood.
