VX Shift Light Location - Fuelly Forums
Old 01-26-2008, 06:46 AM   #1
Member
What light indicator in the dash is for the shift light?
92VX is offline   Reply With Quote
Old 01-26-2008, 07:13 AM   #2
Danronian's Avatar
The one with the white square around it. Only dummy light like that on the cluster. It's below/between the temp/fuel gauge.
Old 01-26-2008, 08:02 AM   #3
Member
None of mine have a white square around an indicator. My car is a California VX so maybe the instrument cluster is completely differnt. I was hoping I could just plop a bulb in and have it work. Do you have a picture?
Old 01-26-2008, 08:24 AM   #4
Member
I found a picture on the internet. I see what you are talking about with the white box around the indicator. I have a bulb location there but it is not wired to anything.
On a side note, it takes a ton of force to pull the plastic around the instrument cluster.
Old 01-26-2008, 11:02 AM   #5
Junior Mint
dogncatboy's Avatar
It comes out gently too, you just have to take the time to locate where it clips in. There are no wires, the bulbs in the instrument cluster are powered by traces that are on the board that holds them, kind of like a printed circuit board.
... D'oh!
dogncatboy is offline   Reply With Quote
Old 01-26-2008, 11:48 AM   #6
Member
Mine did not come out gently, the plastic had never been pulled out. It took considerable force just to get it to unclip on any section.
When I said not wired to anything I meant the printed circuit board. It goes to a section that doesn't plug into anything. Couldn't find any extra wires in the dash that might be hanging out but not plugged in. Looks like the circuit needs to somehow connect to another part of the board. If you follow the printed circuit it went to two holes that weren't wired or soldered to anything. Plus the face of the cluster at that indicator would not allow any light to pass through so I'm skipping on having the shift light.
Old 02-14-2008, 03:22 PM   #7
I have a 1992 California VX, and it doesn't appear to have a shift light either. This is my second VX, and my first was a federal car and it had a shift light, so I know where it is supposed to be.
Perhaps California cars just didn't come with one.
GasSavers_Crazy88 is offline   Reply With Quote
Old 02-14-2008, 05:32 PM   #8
Member
None of the California VXs came with the shift light, I was trying to add one. I was hoping to get away by just throwing a bulb in an empty bulb holder, no such luck. I figured if Honda was lazy enough to leave the good wide band oxygen sensor in the '92 California VXs, maybe they used the same instrument cluster and just left a bulb out.
Tranny fluid flush for FE? brucepick Transmissions and Running Gear 27 07-25-2010 05:03 AM
Congrats to COZX2 on the 100+ MPG fill! MetroMPG General Fuel Topics 58 12-23-2007 07:34 PM
Chrysler to offer a lifetime powertrain warrenty on all new vehicles GasSavers_Red General Discussion (Off-Topic) 6 07-29-2007 05:03 AM
Supermid Arrives! 88HF General Fuel Topics 3 06-23-2007 01:53 PM
Any ideas how to install this? Compaq888 General Maintenance and Repair 0 12-21-2005 12:46 PM
