VX shift indicator light not working when.. - Fuelly Forums
Old 04-13-2009, 02:16 PM   #1
Hi,
I've had a '94 VX for a week now. noticed that the shift indicator light doesn't work with the headlights on. I'm not technical, but I'm not stupid either. Any thoughts on a fix. thanks.
Larry
LarryJ is offline   Reply With Quote
Old 04-14-2009, 02:36 AM   #2
jmf
try replacing the engine ground straps. i just did on my 93 vx and the old ones where ready to fall off. it might not fix it but it cheap place to start.
justin
jmf is offline   Reply With Quote
Old 04-14-2009, 07:24 AM   #3
thanks Justin. I'll look into that. I do get shocked everytime i get out of the car.
I also noticed that I have no dashboard light, so it may just be a fuse.
Old 04-14-2009, 07:30 AM   #4
GasSavers_TomO's Avatar
Check the fuses first, but it sounds like you have a bad dimmer control switch. Run the wheel up and down a few times and make sure it's in the full bright position. If it still doesn't work and you have good fuse on it's circuit, then find a working replacement dimmer switch.
Honda Civic VX Info/Links
Old 04-16-2009, 07:40 AM   #5
..turns out it was just a loose connection with the dash dimmer, which is on the same circuit as the shift indicator light (SIL).
Stealth / Performance Exhaust System Hybrid JohnNeiferd General Fuel Topics 9 07-27-2008 02:40 PM
hi all GasSavers_vdubbinit Introduce Yourself - New member Welcome 0 05-16-2008 09:30 AM
Congrats to COZX2 on the 100+ MPG fill! MetroMPG General Fuel Topics 58 12-23-2007 07:34 PM
Interactive aero modding on VW.com MetroMPG Aerodynamics 5 07-19-2007 05:47 AM
