10-12-2007, 02:22 AM
Originally Posted by Wandering Albatross
So if I understand correctly, 37820-P07-A00 would be a 49-state ECU produced between 92 and 93. It doesn't have the updated code. Is that correct? Perhaps the most ideal situation would be a 37820-P07-A01.
But would the A01 work in a 92-93 VX?
Gary
10-12-2007, 05:13 AM
Most likely. I doubt Honda messed with the ECU connector pinouts or sensor specs or anything, so it should be plug'n'play.
10-12-2007, 08:17 AM
Both the A01 and A00 revisions work in all years of VX Civics. I've personally ran both revisions in my 94. The pinouts are the same as far as connectors. It's just that Honda had made a revision to the 94-95 VX ECU for some unknown reason to me that required the A01 to be added. For all I know, it could be them just changing the Check byte in the coding.
Honda Civic VX Info/Links
Originally Posted by ezeedee
10-22-2007, 11:05 PM
I got my P07-A001 ECU delivered from the Ebay auction I won.
It cost me a total of $60. I was going to wait for the other one that
expired later and had a bid price of $.99. That one ended up going for
$10.50 + 20 shipping. Argh! Oh well, you can't win 'em all.
The ECU had a bit of surface rust so I decided to opened up the metal
box and all is good. The PCB looked shiny with no smoke damage.
Whoever said the Fed ECU has two board is wrong. Just one big PCB, although there was about three sub-boards about 1in x 3in in dimension
(I think that's that they were talking about). I have pics if anyone is
interested in seeing the PCB.
Now I'm going to buy the $79 O2 sensor and I'll be set to do the conversion
(I think).
Gary
03-07-2008, 09:06 PM
Gary, you have a lot of cars! BTW, how did the conversion go?
I'm going to give it a try this weekend. I have the diagram, the O2, and ECU. I'm going to the junk yard to pick up an extra 4-wire connector so I don't have to cut the car's harness.
I'll keep you guys posted.
03-08-2008, 03:35 PM
Originally Posted by gman47
there were 3 models of the vx produced, fed., canadian, calif., the calif. model did not have egr, and only a 4 wire o2 sensor, so how do you tell the difference between the two ecu's?
I always understood that there were actually THREE USDM ECUs: the Federal ECU, the early CA ECU with five wire sensor (but no lean burn) and the later CA ECU with four wire sensor.
04-30-2008, 12:58 PM
I have a '93 CA VX and it has the 4-wire O2 sensor and EGR.
10-19-2009, 01:52 PM
I got a 37820-P07-A00 ecu if any 1 needs hit me up on aim eatcouter
