VX lean burn monitor - enhanced how to desired - Fuelly Forums
Old 12-11-2007, 07:12 AM   #1
Junior Mint
dogncatboy's Avatar
Originally Posted by Danronian View Post
I would also love a how-to on this so I could see when my car goes into lean-burn.
Ditto.
... D'oh!
dogncatboy is offline   Reply With Quote
Old 12-11-2007, 07:17 AM   #2
I carfully shaved the insulation off the two wires just enough to solder into them. Taped them up when i was done.
rlprlp1 is offline   Reply With Quote
Old 12-11-2007, 07:24 AM   #3
93dagsr's Avatar
which ones??...pics??..
https://consumerguideauto.howstuffwor...onda-civic.htm
stupid ricer... useless wings are for pinguins!
93dagsr is offline   Reply With Quote
Old 12-11-2007, 09:00 AM   #4
GasSavers_vxhatch's Avatar
Everything you need to wire a voltmeter, including wire color codes is in the main post, http://www.gassavers.org/showthread.php?t=2427
What I would like to implement instead of a voltmeter is a dash light that glows when in lean-burn mode. I noted when a new member from Portugal described his Civic has a Honda provided "ECONO" indicator that lights when in lean burn. Here's the post: http://www.gassavers.org/showthread.php?t=5535
Read the 5th paragraph and check out the 2nd pic.
A simple comparator circuit could be built to switch a dash mounted LED on whenever the monitored voltage is in the lean-burn range. I'll try and post back with a sample circuit next week.
Doug
GasSavers_vxhatch is offline   Reply With Quote
Old 12-11-2007, 09:54 AM   #5
GasSavers_TomO's Avatar
That members car is an OBD2 version of Civic and that motor is a D16Y5. Different coding than our OBD1 VX so he has a little more bells and whistles from the factory with respect to indicators.
<snip>
Doug
I'm in the process of getting a kit together that will do exactly that for the VX owners. I'm still amassing parts though. I'm thinking that I should be able to get a kit together and out the door this spring if things move smoothly.
Originally Posted by rgsRSX06 View Post
careful with the lean burn, you could get detonation/pining and destroy your engine in short order. You should if you have a Honda check out Hondata for an ecu upgrade that lets you tinker with air-fuel and timing.
Jadziasman is talking about monitoring the signal from the LAF (Linear Air Fuel) sensor currently found on all federal emission 92-95 Civic VX models. There is no modifying of the factory settings for lean burn and therefore no danger of ruining anything.
The P07 ECU that controls the D15Z1 motor is not "chippable" in the known sense of the tuner world. Therefor, Hondata wants nothing to do with the P07 ECU as it uses a 16bit code that differs greatly from the normal 8bit Honda coding.
Originally Posted by jadziasman View Post
So, to those of you who have already wired up their lean burn monitor to D14 and D16, is there any way of doing this without cutting the existing wiring?
I won't be able to take any pictures for a How-To for a while due to it being really cold out. But to let you know, you don't need to cut any wires, just shave off some of the insulation on the mentioned wires (D14 and D16) and solder on a lead to run to your DMM or just use some of those wire taps that don't cut the wire. I prefer the solder method though.
Honda Civic VX Info/Links
Old 12-11-2007, 12:07 PM   #6
jadziasman's Avatar
Thanks TomO, I figured you'd chime in on this sooner or later.
I was also kind of interested in if you had unfasten the ECU from the passenger side wall to get access to D14 and D16. I will wait for warmer weather as well before adding this "feature".
And, you will be helping out many VX enthusiasts if you decide to put together an installation kit.
Old 12-11-2007, 04:06 PM   #7
Sigifrith's Avatar
TomO I'm down for a kit when it's ready.
[SIGPIC][/SIGPIC]
Sigifrith is offline   Reply With Quote
Old 12-11-2007, 04:14 PM   #8
Junior Mint
dogncatboy's Avatar
Thumbs up
I'll take one when ready.
... D'oh!
Old 12-12-2007, 09:53 AM   #9
I'm definitely interested.
When you have a schematic drawn up would you be willing to post it? I'm interested in how the comparator LED switching circuit should be wired. I can have a electrical design engineer look it over as well if this helps you.
doug
Old 12-12-2007, 02:20 PM   #10
I would like to have light that tell me when the Lean Burn is on. I'm wondering why Honda didn't put one from the factory, still its a 1992 model...
Interesting SG2 observations. Compaq888 General Fuel Topics 8 05-06-2007 11:33 AM
U.S. Cars Show No Fuel-Efficiency Gains in 2006 MetroMPG Automotive News, Articles and Products 3 04-26-2007 11:15 AM
Annoying trying to top off tank lovemysan General Fuel Topics 14 10-27-2006 01:46 PM
d15b7 --> d15b2 swappable parts? UfoTofU General Maintenance and Repair 1 10-17-2006 01:41 PM
