VX lean burn monitor - enhanced how to desired - Fuelly Forums
Old 05-12-2008, 11:29 AM   #1
"but quite complicated for an electrical novice like myself"
I'm getting helpful info from a simple DMM. At Harbor Freight they start at $4. That would be enough to monitor mixture (lean burn). I paid more ($33) for a meter with a dwell-angle feature. That lets me monitor how long my injectors are open, which is a direct measure of true, instantaneous fuel consumption.
It's not hard to do. I'd be glad to explain how to do it.
Old 05-13-2008, 03:00 PM   #2
jadziasman's Avatar
I just looked at the 96 - 98 Civic Helm shop manual. It seems that instead of a test harness to connect to the ECU, back probe pin adapters are used on a standard DMM to connect to the pin outs on the ECU.
Has anyone tried this? It looks like it would work to access D14 and D16.
Old 05-13-2008, 04:10 PM   #3
"Has anyone tried this?"
I think some kind of back probe would work fine. Like this:
http://www.backprobe.com/
http://www.smartchargers.com/products/22
Or this:
http://www.amazon.com/Automotive-Bac.../dp/B000I16DKM
But I wanted something cheaper, that I could find locally. Radio Shack had the perfect thing:
http://www.radioshack.com/sm-quick-s...i-2998435.html
Too bad there's no picture. These are called Quick Splice Connectors or T-Tap Connectors. Some more:
http://www.mouser.com/search/Product...538-19216-0018
http://www.vanco-online.com/index.ph...ucts_id=101458
http://www.magnadyne.com/index.cfm?M...&Web_CatID=193
Each approach has its own advantages. The RS product worked great for me, for this exact purpose (tapping wires near the ECU).
I tapped D14 and D16, to monitor AFR. I also tapped A1, to monitor the injectors (this requires a DMM with dwell, but I found one for only $33). This is very helpful, because it gives me a precise indication of instantaneous fuel use.
I also tapped D18, because my car has no SIL (shift indicator light), and I was curious what it would be like to have one.
There are some other interesting things to tap, but so far I haven't bothered.
I've also become very interested in the possibility of using a cheap ($25-50) data-acquisition interface to display/capture all this data on a laptop, instead of a DMM. I think that creates all sorts of interesting possibilities, greatly exceeding what a Scangauge can do. I wonder if anyone here has any thoughts about this idea.
Interesting SG2 observations. Compaq888 General Fuel Topics 8 05-06-2007 11:33 AM
U.S. Cars Show No Fuel-Efficiency Gains in 2006 MetroMPG Automotive News, Articles and Products 3 04-26-2007 11:15 AM
Annoying trying to top off tank lovemysan General Fuel Topics 14 10-27-2006 01:46 PM
d15b7 --> d15b2 swappable parts? UfoTofU General Maintenance and Repair 1 10-17-2006 01:41 PM
