vx headlight problems - Fuelly Forums
Old 12-07-2009, 03:50 AM   #1
jmf
I have a 93 vx, when I turn on the headlights the parking lights come on but not the headlights. If I pull the light lever the brights come on while I hold the lever. After a couple of minutes the low beams come on. It seems worse in the cold. Anyone else have this happen? Any fix?
Thanks
Justin
jmf is offline   Reply With Quote
Old 12-07-2009, 05:39 AM   #2
It sounds like a relay that doesn't work when it's cold.
Old 12-07-2009, 06:48 AM   #3
GasSavers_TomO's Avatar
Either a faulty headlight switch (which is somewhat common) and sound like your problem since you have to hold onto the light stalk. Or faulty connectors at the headlight (also common for these cars).
You can go to a you pull and get a replacement stalk for cheap and all you need is a screwdriver to get it off the car or buy new from honda or your local parts store.
You can buy new bulb connectors from your local car parts store for around $5 a piece. Visually inspect your bulb connectors for any cracking and make sure that they are tight fitting to the bulb. There also should be a tiny amount of bulb grease in the connectors to make them more weather resistant.
Honda Civic VX Info/Links
Old 12-09-2009, 02:44 AM   #4
jmf
Thanks. I wish I had checked the junk yard last week, before this snow.
Lightweight starter batteries Greybrick General Fuel Topics 6 02-02-2008 02:17 PM
Hello All GasSavers_MikeD Introduce Yourself - New member Welcome 3 07-23-2007 10:34 PM
Blast from the past: Mobilegas Economy Runs? Spule 4 General Fuel Topics 8 11-20-2006 07:47 PM
