vx fuel injector resistance - Fuelly Forums
Old 06-27-2010, 07:40 AM   #5
add|ct's Avatar
I agree w/ Erik. RockAuto shows listings for injectors specific to the submodel. The VX replacements don't have P07, but rather P05(isn't that the DX?); and Si has injector parts related to P06 and P10.
Also, the ECU code is at the end of the string for the part number as well. If you needed replacement VX injectors, for instance, and there are none specified for VX(P07), you'd be best lining up a P05 with the right ECU like an A00 or A01; from the 92/93 - 94/95 years ECU code. That's my best deduction.
So, from that I would avoid alternate parts that would probably work, just less likely to have any problems with one specific for your engine. That way too the warranty is still covered as they can't say "you purchased the wrong part for your car" in case of malfunction.
Injector part number: 4G1007(Si) & 4G1296(VX) when comparing ARTEX/WELLS injectors on rockauto.com
'92 Civic VX, Canadian model
FS: New ScanguageII w/xgauge jeffm007 For Sale 5 07-10-2008 12:40 PM
An idea opinions? Joe4pal Electric and Solar powered 3 07-03-2008 02:01 PM
hello siboy Introduce Yourself - New member Welcome 0 05-21-2008 09:43 AM
bike pics lovemysan People Powered 1 03-24-2008 08:09 PM
Hypermiling Auto Trans w/ Tach brucepick Transmissions and Running Gear 4 04-12-2007 11:32 AM
