VX engine and Trans? - Page 2 - Fuelly Forums
Old 06-06-2008, 08:12 AM   #11
GasSavers_TomO's Avatar
The only hurdle to putting the Z1 drivetrain into a 96+ civic is the fact that the wiring harnesses are OBD2. They are wired differently than what the Z1 is set up for. This means buying a conversion harness from Rywire in order to even get the P07 ECU hooked into the wiring harness. After that hurdle, there is the fact that most of the 96-00 model civics have the crank sensor mounted down on the crank itself instead of inside the distributor on the OBD1 cars.
If you really want the comfort and amenities of the 96-00 civics, try to get an HX model. Sometimes you can pick up one with a bad CVT for cheap and do a 5 speed swap into it. Then you're all set for some 44+mpg gaslogs out of the box.
Even the 96-00 Civics share the same rust problem as the 92-95s do. From the factory, the mount to hold the edge of the rear bumper to the sheetmetal above the rear wheel is the culprit for starting the rust. I can get repair panels for dirt cheap for the 92-95 hatchbacks in order to eliminate the rust problem.
I find it easier to get the Z1 drivetrain to work with the 92-95 chassis.
Just my 2?
Honda Civic VX Info/Links
Old 06-06-2008, 10:22 AM   #12
1993CivicVX's Avatar
Originally Posted by swordman View Post
I sold my other car about 3 months ago so the wife and I have been shearing one car a 98 subaru forester which only gets about 24 mpg hwy.
[snip]
Bill
You shearing it in the hopes to improve the aerodynamics? I've heard of waxing cars to make them slippier, but never shearing. I'd like to see a photo of it when it's done.
three stripes the charm!
Old 06-07-2008, 09:44 AM   #13
GasSavers_Binary's Avatar
Checkout or call JDMsource.ca.. I just got a japanese equivalent to the d15z1 and a cx trans (same as vx) from them for a great price, just mention that you are from gassavers and that the last guy who bought one of these engines referred you, Trevor (they refer to us as the gas freaks), and they should really take care of you. I actually was just calling them to get a price and it was so good I bought it right there on the spot.
Big oil execs making 32mil a year and we're paying upwards of $4 a gallon.. Hubberts peak you say? Oh ok, I believe you.
GasSavers_Binary is offline   Reply With Quote
Total gallons used? srellim234 Fuelly Web Support and Community News 3 03-24-2009 04:10 AM
94 Metro XFi on Ebay - Pontiac, MI following For Sale 0 02-20-2008 01:59 PM
Happy Thanksgiving Everyone smccall General Discussion (Off-Topic) 6 11-22-2007 05:10 PM
Tank level when you refill? jandree22 General Fuel Topics 25 08-18-2007 07:01 AM
Gas Prices rising again HEK General Fuel Topics 42 07-13-2007 04:42 PM
