VX EACV Bolt Torque, Other Questions - Fuelly Forums
Old 07-13-2008, 11:43 PM   #1
gork57's Avatar
I'm going to be removing the EACV on my VX to replace the filter (purchased a new filter and gasket for the job). However, on checking my Honda Repair CD, I could not find what torque to use when I put it back in. Does anyone have this info?
In addition, some posters have recommended using brake cleaner to clean out the innards of the EACV. Is this acceptable? Any chance it could damage the EACV mechanism? Should I lube inside the EACV after cleaning? If so, what type of lubricant should I use?
Thanks...
Simplicity is the glory of expression.-Walt Whitman
gork57 is offline   Reply With Quote
Old 07-13-2008, 11:56 PM   #2
gork57's Avatar
Followup Note: I did a Forum Search and found TomO's thread on cleaning a VX EACV (or IACV). Has photos and everything - I should be able to do the job using it. However, no bolt torque specs. Also the post does not mention lubrication after cleaning...
This is touchy stuff. Want to be certain the job is done right. I don't intend to pay $150 for a new EACV unless it is absolutely necessary.
Old 07-14-2008, 04:39 PM   #3
GasSavers_TomO's Avatar
No real torque specs other than about 20ft/lbs on those bolts, enough to be snug and not back out.
I've never sprayed any type of lubricant into the IACV after cleaning as that would attract grime immediately to the IACV, best to keep it squeaky clean
Honda Civic VX Info/Links
Old 07-16-2008, 06:30 AM   #4
kamesama980's Avatar
don't lube the IACV, just take it apart and carb-cleaner the bejesus out of it. for most parts like that with a gasket, tiny bolts, and less than atmospheric pressure behind it, I usually just do the 2 or 3 finger torque wrench... 2 or 3 fingers very near the head of the ratchet
-Russell
Old 07-16-2008, 10:58 AM   #5
I do a pinch grip on the wrench and when it slips between my fingers it's around 12-15ftlb
Carbon fouled O2 Sensor:'92 VX - Perplexed Darkelf General Maintenance and Repair 15 03-17-2008 08:16 PM
old user, new car kamesama980 Introduce Yourself - New member Welcome 0 02-28-2008 05:58 PM
100 MPG Pruis - Australian Silicon Chip mag. GasSavers_Pete Automotive News, Articles and Products 0 02-12-2008 05:53 PM
Better gas mileage for an RV 73challenger General Fuel Topics 5 10-31-2007 04:08 AM
