vx distrib. cap - Fuelly Forums
Old 03-02-2009, 05:38 PM   #1
jmf
vx distrib. cap
i replaced the dist. cap a couple thousand miles ago. i just checked it and the contacts have alot of crud caked on them. i scraped it off and it ran better. one of the screws on the cap was loose, would that cause it to crud so fast? what else would cause it?
justin
jmf is offline   Reply With Quote
Old 03-03-2009, 08:06 AM   #2
A bad seal could be the cause, but typically resistance is the culprit, that is, resistance from the wires and plugs. I'd consider replacing the wires and plugs. I wouldn't spend more than $30 on aftermarket wires, 7mm's are just fine, and stock plugs are only $1.50 or $2 each. Verify the .044 gap, or even go a bit tighter to .040.
I exit lean burn when my life is at risk.
1998 Odyssey 24.1 mpg average
1984 crx project now on the road
hondaguy72 is offline   Reply With Quote
Old 03-07-2009, 05:31 AM   #3
jmf
i have new plugs and wires so i'm thinking it was just the seal.
Hello All GasSavers_MikeD Introduce Yourself - New member Welcome 3 07-23-2007 11:34 PM
over inflate tires for highway driving GasSavers_Ryland General Fuel Topics 8 11-22-2006 05:39 PM
What made you an FE nut? 95metro General Discussion (Off-Topic) 19 06-12-2006 05:47 AM
