VX California VX 1992 - Fuelly Forums
Old 05-31-2008, 01:32 PM   #1
I just bought a 1992 CA VX. The Engine is definately D15Z1. The VIN is correct. And the emmision sticker says CA and Fed. The ECU is P07-L00. This model is kind of unusual: The valve cover gasket does not have the VTEC-E although it looks like a VTEC and the O2 sensor is 5 wire. Any clarification would be appreciated. I am looking to convert to lean burn after I smog it.
kismetsdad is offline   Reply With Quote
Old 06-01-2008, 05:03 PM   #2
Member
Everything is perfectly normal. The valve cover with the VTEC-E didn't come to later. Also the 5 wire oxygen sensor is what the 92 California VX's come with standard, even though the computer doesn't do lean burn.
92VX is offline   Reply With Quote
Old 06-04-2008, 01:14 PM   #3
Yes. I believe the fancy valve cover was used in '94 and '95.
Old 06-05-2008, 11:49 AM   #4
That's how the 92 is. Swap in a federal ecu and you will have lean burn. I found mine on ebay for $50.
thewizard182 is offline   Reply With Quote
Mercedes-Benz B 200 Mike T Car Reviews 18 07-25-2008 10:37 PM
Chevrolet Classic? dletm08 General Fuel Topics 4 11-25-2007 05:25 PM
amazing peak oil poster kickflipjr General Discussion (Off-Topic) 5 11-01-2007 08:57 PM
Front air dam???? brelandt Aerodynamics 6 02-28-2007 06:03 PM
