VX Alternator - Denso vs. Mitsubishi - Fuelly Forums
Old 07-26-2010, 03:41 AM   #1
Member
The Denso alternator on my VX died the other day. The laminations on the rotor got rusty and then started rubbing against the windings on the outer case. Not easily rebuidable.
So I called around and could only find a Mitsubishi alternator locally. The parts listings show only the Denso alternator for the VX and I know that the ECU controls the voltage output of the alternator to maximize gas mileage.
So does anyone know if the Mitsubishi alternator is compatible with the VX?
N2UAD is offline   Reply With Quote
Old 07-26-2010, 04:55 AM   #2
GasSavers_Erik's Avatar
I don't know about the compatibility issue.
I suggest that you check out www.car-part.com It is a quick way to search all of the salvage yards in your area.
You might also check rockauto.com and see if they list both alternators as fitting your car.
Old 07-26-2010, 06:27 AM   #3
Are you trying to buy used or new?
Old 07-26-2010, 06:49 AM   #4
Member
I'm looking for a rebuilt alternator.
Old 07-26-2010, 07:42 AM   #5
add|ct's Avatar
I believe these cars came with either one or the other. The online manual shows pictures of both in the same manual, for servicing them. As long as its the Mitsubishi for the VX. In fact, I think my VX has one of those, not the Denso.
'92 Civic VX, Canadian model
Old 07-26-2010, 01:37 PM   #6
i've noticed in recent years, it's often a better deal to buy new(just a little more $$$)--do not discount a new one!
partial fuel up... pbfoot Fuelly Web Support and Community News 6 12-29-2013 10:54 PM
Hello All GasSavers_MikeD Introduce Yourself - New member Welcome 3 07-23-2007 10:34 PM
Blast from the past: Mobilegas Economy Runs? Spule 4 General Fuel Topics 8 11-20-2006 07:47 PM
