Vtec-e big problem. please help, if you can - Fuelly Forums
Old 02-15-2008, 11:59 AM   #1
i have a problem with my civic vtec -e.
When engine is a hot, cars acceleration is very bad and When i push slow in to the pedal car not accelerate, but if i push in to the pedal to the end after 2-3 second car accelerated well.
expense is 10-11 litre in city.
engine Mileage is 150000.
coolant temperature sensor working is nice and propellеr is running then water temperature come up to 90с.
Repeat! problem show itself when engine is a hot (90c)
replaced:
spark plugs
labda sensor (oxygen)
fuel filter
checked:
cylinder pressure is ok
fuel pump pressure is ok
timing belt is ok.
sorry for my english
usaqmuri is offline   Reply With Quote
Old 02-15-2008, 05:57 PM   #2
mrmad's Avatar
Is the check engine light on?
Have you checked the ignition timing?
I would get the compression tested and if that is in spec, I'd remove the catalytic converter and see what condition it looks like inside. The cat can get clogged and your engine will run like you describe.
Old 02-16-2008, 01:14 PM   #3
GasSavers_Ryland's Avatar
Is this a recent problem? or a new car?
I would check your ignition timing, and your cam timing, when I had my timing belt install wrong (one notch out of place) it was really slugish.
your cylender compression should be 195psi, 13.44 Bar, and not more then 20psi or just over one bar variation from cylender to cylender.
Also, when you changed your spark plugs how did the old ones look? if you take one to a mecanic, or auto parts store they should be able to tell you if you are running trying to burn to much gas.
Old 02-17-2008, 03:39 AM   #4
The check engine not show me any errors
Old 02-17-2008, 03:49 AM   #5
compession is a normal.
catalytic converter does not stand
Old 02-17-2008, 08:41 PM   #6
have your timing dubble checked, there is a set of arrows on the head that the cam gear lines up with when the crank shaft mark is lined up with the pointer, after you have that done, have them check it with the timing light as well for ignition timing.
Old 02-19-2008, 11:17 AM   #7
timing is ok.
The problem proves to be, when the engine is a hot (90c)
Old 02-22-2008, 12:57 PM   #8
Possibly problem because of the distributor?
Old 02-22-2008, 04:09 PM   #9
Yeah, take the cap off the distributor and take a look at it, and also look at the rotor...replace if there is a problem.
GasSavers_James is offline   Reply With Quote
Old 02-23-2008, 05:29 AM   #10
how i can know is this problem from the distributor?
Pictures posted garyhgaryh General Maintenance and Repair 1 10-27-2007 07:57 AM
Not getting impressive fuel economy with the Civic DUBPL8 General Maintenance and Repair 31 08-25-2007 04:12 PM
Volkswagen Diesel Quantum '84 zpiloto General Fuel Topics 10 06-14-2007 08:39 AM
Things To Look For When Buying A Civic Hx panamacolin General Fuel Topics 9 06-06-2007 08:43 AM
Thinking of buying a Fast car? Compaq888 General Discussion (Off-Topic) 10 01-09-2006 11:18 AM
