VSS issue - Page 2 - Fuelly Forums
Old 03-23-2008, 07:59 AM   #11
1993CivicVX's Avatar
Originally Posted by vxdude View Post
also along with the speedometer not working the odometer doesnt work either and the shift light. But i think all of that works off of the VSS.
When my speedometer/odometer are not working, my Shift light still comes on.
three stripes the charm!
Old 04-12-2008, 05:38 PM   #12
vxdude's Avatar
Send a message via Yahoo to vxdude
UPDATE!!!! The VX takes a "special" VSS, its the one at advance auto parts the brand name is Niehoff, Nippon Seiki. Cost anywhere between 100-125. I tried 5 speed senors, then i tried this one. WORKS GREAT. after about 100 miles no problems to speak of yet!!
vxdude is offline   Reply With Quote
Old 04-14-2008, 07:38 AM   #13
Danronian's Avatar
I have noticed that some D-series Honda trans VSS have metal gears whereas the VX ones are usually plastic.
Does this sound correct from your experience with these VSS?
Old 04-15-2008, 07:39 PM   #14
vxdude's Avatar
I dont recall but i will check sometime, although the VSS isnt the issue i think, i will be replacing the speedometer cluster here shortly, still having trouble..grrrrrrrr
Old 04-15-2008, 09:57 PM   #15
Danronian's Avatar
I had a CEL on mine once due to corrosion at the VSS plug, but thankfully my 253k mi VSS and cluster are still good in my VX.
Old 06-02-2008, 09:12 AM   #16
vxdude's Avatar
Yes Sir the cluster for the speedometer was bad, so instead of replacing the whole cluster with another one, i just replaced the circuit board of the speedometer of the cluster, easy fix
Old 06-03-2008, 10:55 AM   #17
Danronian's Avatar
Glad to hear it was an easy fix.
Old 06-03-2008, 05:24 PM   #18
Great! You can come by and fix mine anytime.
Fuelly Requests S4Lee Fuelly Web Support and Community News 8 10-17-2011 01:28 AM
Not so Smart aerodynamic fairing GasSavers_Antoine Aerodynamics 12 10-23-2007 03:59 PM
Brakes 1993CivicVX General Fuel Topics 3 10-05-2007 04:27 AM
what more can I do? kitcar Aerodynamics 19 06-18-2007 03:34 PM
