Well, I have to search threw the Service manual but figured someone else might know the answer too...
I've been throwing a VSS codes lately...sometimes with no signs, on long trips I will lose my speedo all together (also my trip meeting
) Well now I swapped out my VSS last night and after a short while, since he car was still warm from the 2 hour trip I just got home from, the speedo dropped again so I've determined that the sensor isn't the problem and its now electrical, I sprained out the VSS and the plug with some automotive electrical cleaner when I installed it so I imagine it is else where...
My question is does the VSS signal go to the Cluster before the ECU, does the signal split and go to each separately? I am curious if it goes to the cluster first if my the problem is my speedo..I have a spare cluster I can swap the speedo out of and a spare dash harness that goes to the cluster if I need but figured someone might know... I am going to test the VSS plug to the shock tower harness plug to make sure it isn't in the engine harness...only problem is I need to drive around and get the speedo to stop working before I can test since it seems once the wires are warm is when they drop...
Any help is appreciated thanks!
