Using Larger Oil Filter? - Page 2 - Fuelly Forums
Old 03-28-2008, 12:58 PM   #1
cfg83's Avatar
Hello -
I was wondering about this post by CheapyBob :
Switched to Amsoil today.
Originally Posted by cheapybob View Post
My race car dynoed 20 more hp when the oil level was reduced 1/2 way down the dipstick instead of at the full line. I do the same on my Saturn as I figure the same drag that would reduce hp would also reduce mpg. I run a larger filter, which is below that height, and increases oil capacity by 1/2 pint to offset.
My questions are :
1 - What do you think of using a larger oil filter for MPG?
2 - Are most oil filter connectors the same? If yes, then it's moslty just an issue of clearance.
3 - If it helps MPG, then how? Would it be because the area of the filter is larger or there is less pumping losses?
4 - Could the engine be hurt in some way?
Thanks,
Mercedes Stop-start technology lunarhighway Automotive News, Articles and Products 0 07-30-2007 03:46 AM
TPS Will a 88 Civic DPFI TPS Work on a 92-95 D15z1 8Civic8 General Maintenance and Repair 2 11-09-2006 10:12 PM
