Spark plugs work on high-frequency, so peak current and voltage wouldn't be as important as the wave shapes. The idea is that you charge the coil with low voltage, then open it across a capacitor (an LRC circuit). It then oscillates at high frequency, which causes a pretty healthy voltage on the primary, and high voltage on the secondary. I think they're wound 100:1 or so.
I think the current would be mainly set by the plug wire resistance. You would get a high voltage until the arc is struck, then it would decrease to maybe 100 volts. Lower pressure means higher voltage. They absorb the rest of the voltage in the plug wires. I'd guess hundreds of mA peak.
Probably the best way to get an idea of this is to measure low-side current on either a plug or the coil. You would need a scope for sure.
So why are you interested in the plug current anyway?
