Tricking the PCM/ECU into lean burn? - Page 2 - Fuelly Forums
Old 12-20-2006, 08:56 PM   #11
cfg83's Avatar
DRW -
Originally Posted by DRW
On my car there is a separate switch on the throttle body that tells the ecu when the throttle is fully closed. The switch is used only for coasting fuel cut.
I'd imagine other cars are using something similar. The fuel cut couldn't be dependant on the vehicle slowing down, otherwise you'd stall everytime you went uphill.
What about stepping on the brake and gas at the same time? Does it cut fuel on your car?
When I hit the brake/gas pedals at the same time, the engine revs up and overcomes the brake (like the drifters do!!!!). The PCM must have a rock-paper-scissors rule where the brake state is ignored if the user presses the gas pedal. Gas beats brakes.
Old 12-20-2006, 09:01 PM   #12
cfg83's Avatar
Hello -
Thank you for all the responses. Most of what you are writing tells me I need to do alot of homework.
Merry Christmas!
Old 12-20-2006, 09:25 PM   #13
On my car the fuel cut only has to do with the throttle being closed, meaning .5 volts or so from the TPS. And if the RPM is above a certain limit, which generally depends a little bit.
Number Section of iOs keyboard boostventilator Fuelly Web Support and Community News 5 09-23-2012 10:23 AM
A Couple of Possible Additions mechjames Fuelly Web Support and Community News 3 02-13-2010 11:16 AM
