Tree animals eat my fuel injector cables and one more? Hellpppppppp - Page 4 - Fuelly Forums
Old 08-05-2012, 07:04 PM   #31
sebass's Avatar
Re: Tree animals eat my fuel injector cables and one more? Hellpppppppp
Erik so you're saying that in your 87 honda that is your warning light on your dashboard that alerts you that your oil is low? Am I getting this right?
If so even if cut that won't affect any mechanical workings of the engine but only you would be blind if car would be low on oil? Am i getting this right?
sebass is offline   Reply With Quote
Old 08-05-2012, 08:17 PM   #32
GasSavers_Erik's Avatar
You could drive without it if it is indeed the wire to the oil pressure switch.
It controls an oil pressure warning light (not oil level). It comes on when there is no oil pressure (when the key is on but the engine is not running) and goes off shortly after the engine starts. The sensor is a simple switch that stays closed unless there is sufficient oil pressure (5-10 lbs) to open it.
FYI- if it is the oil pressure switch wire, if the bare wire comes in contact with the engine block, your oil pressure warning light will come on. If the wire has been completely severed, the oil light will not come on even when you have the key on with the engine not running.
Old 08-06-2012, 08:58 PM   #33
sebass's Avatar
Jay and Erik I would like to thank you very much. This helped me A LOT.
Erik i will go ahead and try to verify what that cable is on my car but my oil light lights up when i turn the key and lights off when i start. I sort of hope it is the oil light indicator.
