Tire size differences...how much is acceptable for ABS and differential? - Page 2 - Fuelly Forums
Old 11-21-2010, 05:13 PM   #11
kamesama980's Avatar
Re: Tire size differences...how much is acceptable for ABS and differential?
in 2wd, you're fine. in snow in 4wd, you're probably fine. the key is that on snow/ice the tires will slip to account for any minute differences.
IIRC the owners manual says not to use 2wd unless you're on slippery surfaces so I'll leave that there with the transfercase. it does not slip so the weakest link will go. whether the weakest link is tire traction, U-joints, or the t-case itself who knows.
I wouldn't worry about how the tires roll dismounted at all. you could inflate them all to the same pressure and they end up in the opposite order with the weight of the truck on them.
-Russell
Old 11-22-2010, 01:05 PM   #12
Got the Pirelli tires today they smell nice in the trunk - they have a really big groove in the center of the tread and are only a little bigger in radius so not that big a difference in size. Supposed to be 3/4 inch larger in diameter than the factory 60 series.
A friend with a F150 truck got some other weird brand from TireRack and man did they stink even outside you didn't want to stand anywhere near the truck.
Old 12-09-2010, 12:54 PM   #13
LOL I know what you mean. I love that smell.
OfficeLinebacker is offline   Reply With Quote
