tire size big or small - Fuelly Forums
Old 02-05-2007, 11:43 PM   #1
If I put smaller tires on my car is that better or worse for mpg and if I have smaller tires in the front than in the rear or vice versa could this damage my car.
95_corolla is offline   Reply With Quote
Old 02-06-2007, 06:35 AM   #2
skewbe's Avatar
Well if your current tires are in decent shape I personally would just pump them up to whatever PSI your comfortable with. Otherwise there'll be more tires in the landfill.
If due for replacement, keeping them the same size would be best for alignment/steering geometry/tire rotation purposes. You'll have more caster if the front tires are smaller.
It shouldn't cause any immediate damage though, unless the bumper is dragging
Standard Disclaimer
Old 02-06-2007, 11:19 AM   #3
ELF
ELF's Avatar
Depends on where your driving, all city/ stop and go smaller tires might help mpg. .
but if you do a lot of hwy then smaller might cause a slight loss.
Old 02-06-2007, 02:31 PM   #4
Team OPEC Busters!
GasSavers_Brock's Avatar
Typically larger tires will have a higher rolling resistance, but also might give the advantage of lower RPM at cruising speeds. On the TDI forum larger tires almost always decrease the MPG.
Old 02-06-2007, 02:57 PM   #5
skewbe's Avatar
And you will have less caster if you put smaller tires on the front!
My bad. You will indeed have less caster. Less caster can mean harder to drive in a straight line.
Peakster! how is straight line driving with the doughnuts on front?
Standard Disclaimer
Old 02-06-2007, 03:19 PM   #6
Peakster's Avatar
It was a bit interesting . There did seem to be a bit more side movement at highway speeds, but I just thought it was because of the wind, and less grip on the ground.
Wikipedia: "A caster (or castor) is a type of wheel mounted with an offset steering pivot such that the wheel will automatically swivel to align itself to the direction from which it is pushed. They are commonly found on shopping carts and rolling chairs."
iphone experience bearmeister Fuelly Web Support and Community News 5 02-10-2010 11:25 PM
electric l/100km MJ/km Efried Fuelly Web Support and Community News 2 08-25-2008 08:41 AM
195* Tstat SVOboy Experiments, Modifications and DIY 12 04-17-2007 08:27 AM
MetroXFi changed his name! SVOboy General Discussion (Off-Topic) 26 04-09-2006 07:38 PM
VX -- Del Sol engine swap GasSavers_moses General Fuel Topics 28 01-06-2006 04:38 PM
