Tips on Valve adjustment - Page 2 - Fuelly Forums
Old 08-27-2008, 07:31 AM   #11
Member
TDC is overrated. I just rotate the engine (in the proper direction, like erik said) until the valve I want to adjust closes, rotate a bit more, then adjust it. Valves are either completely closed, or open, they don't stay partially open for any length of time. Even the vtec-e valve will open slightly when you spin the engine, be sure it closes - then adjust. I also agree - you don't need a fancy tool, box wrench and screwdriver will do fine. Good luck.
nowhhs is offline   Reply With Quote
Old 08-27-2008, 08:19 AM   #12
Years ago when I did a valve job on Rusty I adjusted the valves while the engine was idling with the valve covers off. The valves were perfect the first time, but there was some spillage onto the exhaust manifold that burned off over the following day or so.
Old 08-27-2008, 08:48 AM   #13
Is it necessary to replace the valve cover gasket on the VTEC-e or is it reusable?
SCoupe is offline   Reply With Quote
Old 08-27-2008, 08:58 AM   #14
I would never reuse an old valve cover gasket, no matter how good it looked when I took it off. You are asking for leaks.
Old 08-27-2008, 11:30 AM   #15
Jay, American V-configuration engines can (and some should) be adjusted while running since the adjuster is also the rocker arm retaining nut and doesn't move with the rocker arm. Hondas and other imports carry the adjuster on one end of the rocker arm itself (usually right above the valve), and can't be adjusted while running.
Replacing valve cover gaskets is always recommended, but I can say that I've gotten lazy or forgetful a time or two and if you clean everything thoroughly you can get away with re-using them once depending on the age. I'd consider this more of an emergency repair or last resort (say if the dealership and parts store are out of gaskets for example) than a normal work practice though.
GasSavers_Hal9000 is offline   Reply With Quote
Old 08-27-2008, 02:22 PM   #16
Member
Unless you break it taking it off, or its brittle, I would reuse the valve cover gasket. I've had my valve cover off twice and reused the same gasket without any leaks. I agree it isn't ideal, if I had a gasket set I would use a new one, but on a Honda it usually works.
Old 08-27-2008, 03:05 PM   #17
@ HAL9000
I've only ever worked on American vehicles. Most were GM V6's & V8's. The closest to foreign cars my family had were Chrysler K cars. I think some of them had Chrysler engines, and I think my Mother's old 1988 LeBaron had a Mitsubishi engine in it. I never had the valve covers off of that LeBaron though. Tough little car. Mom had almost 200,000 miles on it when she sold it, and she sold it to her best friend's son who put another 100K+ on the car till he totaled it.
Old 08-27-2008, 03:47 PM   #18
No problem. I wasn't trying to be snippy or anything. Just making the point so some of the less mechanically inclined viewers wouldn't get confused (Imagine trying to adjust valves when the adjusting screw is bouncing up and down 15 times a second!)
FWIW, even though I've owned an american car or two, I've only ever made valve adjustments on my foreign cars which have to be adjusted off and cold...
Oh yeah; domggg, make sure that when you adjust your valves the engine is stone cold.
Old 08-27-2008, 03:57 PM   #19
Oh no, I didn't take it that way. No problems. I wasn't aware there were engines that can't be adjusted while running.
Old 08-27-2008, 05:21 PM   #20
panamacolin's Avatar
How often do you adjust the valves? What are symptoms for doing this procedure. My 95 VX has 108,000 miles on it at the moment. I have owned it since 98k, When should I do this procedure.
My car is running great at the moment...just wondering if I should mess with it?
panamacolin is offline   Reply With Quote
Feature request: input "validation" override Volta Fuelly Web Support and Community News 8 08-20-2008 12:20 AM
need help with scan gauge bowtieguy General Maintenance and Repair 4 08-16-2007 04:12 AM
Need Math Help! Bubba Bob General Fuel Topics 13 06-13-2007 05:49 PM
1989 Civic, massive economy drop, question. Gary Palmer General Fuel Topics 8 12-09-2006 08:24 AM
WAI revisited. zpiloto General Fuel Topics 14 05-16-2006 03:08 PM
