The CRX is in - Fuelly Forums
Old 10-31-2006, 01:46 PM   #1
hoffmann277's Avatar
Send a message via MSN to hoffmann277
The CRX is in
Just got her in today after a second 2 1/2 hour drive to pick her up. Total driving time: 10 1/2 hours. Extra half hour cause I got lost coming home the first time. What a pain. I was unable to pick it up the first time because I had brought a dolly, and of the course of the time the car had been sitting, aprox. 2 months, both the passenger side wheels were locked/frozen. The guy fixed the problem, he worked at a Kia dealership, and I made a second journey up and that ends the story of the tedious trip to get my CRX.
ID:	39   Click image for larger version
Being born is like being kidnapped. And then sold into slavery.
hoffmann277 is offline   Reply With Quote
Old 10-31-2006, 02:17 PM   #2
Nice. Have you decided if you're doing the VX engine swap, or sticking with the HF motor?
Old 10-31-2006, 03:43 PM   #3
that's a lot of drivin, but a nice car you got there!
budomove is offline   Reply With Quote
Old 10-31-2006, 04:02 PM   #4
Matt Timion's Avatar
THe more I think about it, I do believe that a rebuilt HF engine would be very easy and could provide nearly the same results as a VX motor...
and it'll be super easy and cheap to do (relative to the VX swap). If I had a CRX HF, that is exactly what I'd do.
Then again, this isn't about me... it's about hoffmann277. Whichever route your take, there are more than enough of us to help guide you through it.
Old 10-31-2006, 07:56 PM   #5
Compaq888's Avatar
What motor is in the car now? Usually an aftermarket exhaust indicates a modification to the engine. Possibly an engine swap.
Old 11-01-2006, 12:57 AM   #6
Original motor I believe. I'll take picks of the engine bay in the morning. Brand new full exhaust, new headers, and a cold air intake appear to be the only mechanical "upgrades." It also has fiberglass(I believe) driver's and passenger's side front wheel wells. Wonder how much weight is saved there. Pics of those too in the morning.
Oh, and I'll be sticking with the HF engine for now, that is of course assuming that I fine the block in good condition when I tear it apart.
I'll just be replacing the head gasket. I talked to a Honda mechanic today in his opinion he'd replace the piston rings and the rod bearings while having the engine torn apart like this and with the mileage this car has (210K something.) I'll test the compression hopefully tomorrow and see where it goes from there.
Old 11-01-2006, 08:32 AM   #7
LincolnW's Avatar
Great find! It looks to be in pretty good shape too. I'm sure with a little TLC it will be a great gas saver.
About the rebuild: don't pull the slugs out unless you really need to. No need to replace the rings and bearings unless it really needs it. I see too many people spend lots of money on rebuilding engines that don't really need it. I'm a fan of just driving it until it REALLY needs it. lol
LincolnW is offline   Reply With Quote
Old 11-01-2006, 09:33 AM   #8
uh, are you serious? An aftermarket exhaust usually indicates an aftermarket exhaust.
I can't tell you how many times I've gone to the junkyard looking at these old cars with aftermarket exhausts, shaved door handles, custom paint, custom interior, etc., only to find the stock engine in there.
That exhaust is more about looking tough than actually being tough.
Old 11-01-2006, 10:18 AM   #9
Well I will be sticking with the HF motor if it runs fine after the gasket change then. Do you really think though that it could match the VX's engine Matt? I commute 30 miles to work, I would have thought the lean burn for my sort of traveling would give the VX engine the edge. At the moment though, no matter what I'll be sticking with the HF motor if it runs fine after the gasket change for the funds are low at the moment.
Thanks for the advice Standard, I decided not too also because I don't know what other problems it might have. Maybe if I feel like being nice if she runs alright.
The pics though, here we go. You may oogle now, ordered the service manuals, you may gawk then.
Name:	1991 CRX HF - Under The Hood - 300 Pixels Short Side.JPG
ID:	41   Click image for larger version
Name:	1991 CRX HF - Headers.JPG
ID:	42   Click image for larger version
Name:	1991 CRX HF - Front Driver's Side Z3 Panel - Rear View.JPG
ID:	43   Click image for larger version
Name:	1991 CRX HF - Front Driver's.JPG
ID:	44   Click image for larger version
Name:	1991 CRX HF - Interior - Dash.JPG
Old 11-01-2006, 10:31 AM   #10
MakDiesel's Avatar
That's a D15B6 throttle body all right, anemic and proud...And who's 280 is that in there as well? Any info on it? (I used to have 2 Z's ('72 240z/'81 280zx) til my first college tuition bill...then it became Honda CRX/Hatches...I'll eventually have both again) Nice find on the CRX, Mak
'85 CRX Si Original EW3 @ 254k...suck it Detroit
'89 CRX HF-Z1 ~ When haste is needed
'97 Civic DX Hatch ~ Formerly 600hp, now 0hp, soon 115hp.
MakDiesel is offline   Reply With Quote
Tags in SMS messages elliottcable Fuelly Web Support and Community News 1 12-15-2011 12:28 PM
How to change fuel type JayHoe Fuelly Web Support and Community News 3 06-15-2011 12:14 AM
gasoline and veggie oil, to much time to think. GasSavers_Ryland Experiments, Modifications and DIY 35 06-30-2008 05:20 PM
1995+ Metro Front Brakes 95metro Experiments, Modifications and DIY 15 07-04-2006 02:12 PM
adding batterys bagpipe goatee Electric and Solar powered 3 02-06-2006 04:03 AM
