That pcv valve... - Fuelly Forums
Old 09-11-2008, 12:08 PM   #1
That pcv valve...
looks like a pain to change. Plus, I had a hard time finding it. i thought they were usually up on the valve cover somewhere. Anyhow, getting to that bottom hose connect is looking tough from the top but its looking like its its gonna be tight getting in from the bottom also. I am gonna have a reason to raise the car fairly soon (torn cv boot). Is it easier to get to that bottom hose from under the car? 93 DX HB by the way.
Rick
Civicrick is offline   Reply With Quote
Old 09-11-2008, 08:09 PM   #2
GasSavers_bobski's Avatar
Look at your intake manifold... On the front of the plenum (the part that distributes air from the throttle body to the 4 runners) there should be 2 or 3 vacuum lines. One of them is larger than the other(s) and runs down to a plastic elbow stuck in a holder between two of the runners. That plastic elbow is the PCV valve.
Old 09-12-2008, 05:00 AM   #3
Originally Posted by Civicrick View Post
looks like a pain to change. [snip] Is it easier to get to that bottom hose from under the car? 93 DX HB by the way.
Rick
If you need to change the connector hose from the "black box" to the intake manifold, it's probably easier to get at it from below.
If, however, you only need to change the PCV valve itself - it just pops in and out from above quite straightforwardly. A bit snug sometimes but nothing complicated.
Darkelf is offline   Reply With Quote
Old 09-12-2008, 07:02 AM   #4
Loserkidwac's Avatar
Send a message via AIM to Loserkidwac
#6 is the PCV follow the big vac hose on the front of the intake plenum it will lead you right to it, just give it a little tug and twist should pop out
MPG Noob
03 Mazdaspeed Protege
91 Honda CRX Si
95 Honda Civic VX *RIP 5/20/08
94 Honda Del Slow D15z1 Swapped
Loserkidwac is offline   Reply With Quote
Old 09-12-2008, 07:52 AM   #5
aalb1's Avatar
I may get flack for this but I've never bought a new PVC valve. I always just use carb cleaner and clean it till it rattles.
$.50 worth of carb cleaner from a $1.99 can or $5 for a new PVC valve. It makes sense to me.
Old 09-12-2008, 08:34 AM   #6
haha.....I have done that also several times, although I usually just get a new one since they are not expensive and don't need to be replaced often..Then I saved the old cleaned out one for a spare. So let the flack begin.
Dave
GasSavers_GasUser is offline   Reply With Quote
Old 09-12-2008, 07:59 PM   #7
Danronian's Avatar
Be careful with pulling it out. I've had them break before and then that makes a mess of things. You might want to spray some pb-blaster around it to loosen it up a little.
Old 09-12-2008, 08:59 PM   #8
Assuming you can clean it out thoroughly, that's really the only issue with re-using old valves: the plastic gets brittle over time, making it easier to break.
Highest MPG V8? bobc455 General Fuel Topics 58 02-27-2013 05:21 PM
Average incorrect RobotCaleb Fuelly Web Support and Community News 1 08-03-2009 01:10 PM
some more familiar driving, LOL Compaq888 General Discussion (Off-Topic) 20 04-07-2009 02:37 PM
Timing chain and FE bowtieguy Experiments, Modifications and DIY 22 11-11-2007 09:48 AM
Interactive aero modding on VW.com MetroMPG Aerodynamics 5 07-19-2007 06:47 AM
