taller tranny - Page 8 - Fuelly Forums
Old 07-10-2006, 07:57 AM   #71
OK Ben: since you can't wait to find out (neither could I)
For an average FE improvement of 8.8%
Feeeeee!
Old 07-10-2006, 08:02 AM   #72
RPM difference!?!?
Anyway, what's the lowest speed you can go in 5th with the new transmission?
Old 07-10-2006, 08:14 AM   #73
RPM difference @ 65 km/h
Old 07-10-2006, 08:14 AM   #74
95metro's Avatar
So when are you going to attempt a 110 mpg segment?
95metro is offline   Reply With Quote
Old 07-10-2006, 08:23 AM   #75
YA RLY!
Old 07-10-2006, 09:36 AM   #76
No pressure, eh?
I don't think the new legs are going to make much of a difference in city/suburban driving, where I did the 101 mpg loop.
I may try again sometime though.
Now that this is done, I'd like to have a second look at the belly pan. But not likely soon. I want to get back to Project ForkenSwift.
Old 07-10-2006, 09:40 AM   #77
95metro's Avatar
Originally Posted by MetroMPG
No pressure, eh?
No, no pressure
The lower rpm acceleration should help a little. Too hard to say how much. Can you still shift at 15, 30, 40, 50 or do you have to stretch it out a little more?
Old 07-10-2006, 09:46 AM   #78
But with taller gearing and aero mods going 50 will be like going 40, and then you can speed your way to victree.
Old 07-10-2006, 09:53 AM   #79
Yeah, theoretically, the lower RPM should help with the moderate load/low RPM accel technique. (But it's not proven one way or the other yet)
Old 07-10-2006, 10:20 AM   #80
95metro's Avatar
I definitely have to shift later now. Up by approximately 7-10 km/h per gear. (e.g. 1-2 @ 25k, 2-3 @ 35-40 k, 3-4 @ 45-50 k, etc.)
So cruising in 5th will definitely see the major benefit since your shift revs are probably similar to the old transmission.
I just realized - you've got a practically new 1.0L transmission lying around now...
Thank Uncle Sam for high gas prices bear15 Automotive News, Articles and Products 9 08-15-2007 08:43 AM
LPG conversion SVOboy General Fuel Topics 4 03-24-2007 10:33 PM
Auto to Manual Reverse Light Question SVOboy General Fuel Topics 9 03-15-2007 10:28 PM
Free flow exhaust GasSavers_Kraig General Fuel Topics 9 08-07-2006 08:53 AM
